Just added a Raspberry Pi Pico and an ADXL and noticed that Klipper is reporting the CLOCK_FREQ at only 12Mhz?
mcu 'pico': Starting serial connect
Loaded MCU 'pico' 94 commands (v0.10.0-256-g6d7c0336 / gcc: (15:8-2019-q3-1+b1) 8.3.1 20190703 (release) [gcc-8-branch revision 273027] binutils: (2.35.2-2+14+b2) 2.35.2)
MCU 'pico' config:
ADC_MAX=4095
BUS_PINS_i2c0a=gpio0,gpio1
BUS_PINS_i2c0b=gpio4,gpio5
BUS_PINS_i2c0c=gpio8,gpio9
BUS_PINS_i2c0d=gpio12,gpio13
BUS_PINS_i2c0e=gpio16,gpio17
BUS_PINS_i2c0f=gpio20,gpio21
BUS_PINS_i2c0g=gpio24,gpio25
BUS_PINS_i2c0h=gpio28,gpio29
BUS_PINS_i2c1a=gpio2,gpio3
BUS_PINS_i2c1b=gpio6,gpio7
BUS_PINS_i2c1c=gpio10,gpio11
BUS_PINS_i2c1d=gpio14,gpio15
BUS_PINS_i2c1e=gpio18,gpio19
BUS_PINS_i2c1f=gpio22,gpio23
BUS_PINS_i2c1g=gpio26,gpio27
BUS_PINS_spi0a=gpio0,gpio3,gpio2
BUS_PINS_spi0b=gpio4,gpio7,gpio6
BUS_PINS_spi0c=gpio16,gpio19,gpio18
BUS_PINS_spi0d=gpio20,gpio23,gpio22
BUS_PINS_spi1a=gpio8,gpio11,gpio10
BUS_PINS_spi1b=gpio12,gpio15,gpio14
BUS_PINS_spi1c=gpio24,gpio27,gpio26
CLOCK_FREQ=12000000
MCU=rp2040
PWM_MAX=255
STATS_SUMSQ_BASE=256
STEPPER_BOTH_EDGE=1
mcu_temperature 'pico' nominal base=437.226612 slope=-1917.489831
Raspberry Pi foundation states “up to 133Mhz”: Raspberry Pi Documentation - Raspberry Pi Pico
Not that the faster speeds are necessary to get the resonance calculations down, but there is a big difference between 12Mhz and 133Mhz.
Mainsail is also reporting 12Mhz.
I double checked the make menuconfig and there is no options for clock speed.
I’m going to guess that Klipper is reporting the 12Mhz crystal speed, not the processor speed?
Thanks!
