Hi all, I am encountering an issue that I haven’t been able to resolve by myself so far, I hope you guys can help me out. Recently, I have had a few prints fail due to the Pi shutting down mid-print. I have tried to resolve this myself, but no success so far. I have been looking around, but couldn’t find a topic that addressed the same issue. Hopefully the information below helps to point someone more knowledgeable in the right direction.
Printer Model: Ender 3 (the ‘original’ model)
MCU / Printerboard: BigTreeTech SKR V1.3
Host / SBC: Raspberry Pi 3 model B V1.2 (1GB RAM, if I recall correctly)
klippy.log: klippy.log (967.8 KB)
Additional Information:
The Pi is powered by an original 2.5A RPi adapter.
I suspected a faulty SD card, so recently migrated to an SSD.
The SSD is connected using the original RPi USB hub, powered through another original RPi adapter.
The printerboard is directly connected to the Pi. On the board, there is a header which allows to select the MCU 5V supply. I selected the external PSU to provide this (so not the 5V line on the Pi). I’m using the USB-cable that was shipped with the printerboard.
The Pi controls a 4-channel relay to control the mains power to the PSU, enclosure lights, tool light and extraction fan. The 4-channel relay is powered by the Pi.
The print starts fine, no issues at all. At some random point in the print, the whole printer just shuts down. The Pi becomes completely unresponsive, I cannot access it through a webbrowser or SSH. Even pinging the Pi’s IP-address or scanning the network does not provide any response, it’s just completely unresponsive. Power-cycling the Pi brings it back alive, and everything works completely normal again. There are also prints which are completed without any issue at all, it seems to be a completely random event.
I hope someone can be of help, please let me know if I can provide any additional info, thanks very much in advance!
Update 1:
Just after posting this message I started a short print (30 minutes), during which the printer also failed, to my own surprise. The last two failures were on +5 hour prints, not during prints this short. I started listing for myself what I changed recently, and figured that the new Nebula camera could be something to rule out. Even though it’s powered by the external USB hub and adapter, I was concerned that maybe processing and sending all the footage would cause the Pi to go bad. I ran the processing script on Graph Klipper Stats and noticed that the klippy.log shows very high bandwidth usage (see screenshot below). Not sure if that’s what causing the issues, but worth ruling out. I removed the camera, made sure to update all firmware on the Pi, and re-started the 30 minute print, which finished perfectly. I now started a longer print (6’ish hours) which failed earlier, again without camera, and will report back once it finishes or crashes again…
