Printer Model: Cartesian
MCU / Printerboard: Fysetc Spider V2.2
klippy.log Don’t have one yet
I am trying to configure Klipper to run my Cartesian 3D printer. I am having trouble with the diag pin for sensorless homing and the Fysetc TMC2209 v3.0 driver. Klipper keeps giving me this error " pin virtual_endstop used multiple times in config". I have been through the configuration multiple times and cannot see the conflict. The X and Y pins on the Spider V2.2 board share pins PB13 and PB14 with the X and Y min endstop connections. I want to use sensorless homing. When I add the diag pin configuration to my printer.cfg file, it comes back with the error. How do I configure the Spider V2.2 board with the Fysetc TMC 2209 V3.0 drivers to use sensorless homing in Klipper?
My configuration -
# Spider v2.2
[stepper_x]
step_pin: PE11
dir_pin: !PE10
enable_pin: !PE9
rotation_distance: 40
endstop_pin: tmc2209_stepper_x:virtual_endstop
position_endstop: -18
position_min = -20
position_max: 300
homing_speed = 45
full_steps_per_rotation: 200
step_pulse_duration: 0.000000100
homing_retract_dist = 0
[stepper_y]
step_pin: PD8
dir_pin: !PB12
enable_pin: !PD9
position_endstop: 3
position_max: 300
homing_speed = 40
step_pin: PD14
dir_pin: !PD13
enable_pin: !PD15
rotation_distance: 8
position_min = -2
position_max = 280
homing_speed = 12
[stepper_z1]
step_pin = PE6
dir_pin = !PC13
enable_pin = !PE5
microsteps = 16
rotation_distance = 8
step_pin: PD5
dir_pin: !PD6
enable_pin: !PD4
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
pressure_advance = 0.15
pressure_advance_smooth_time = 0.1
smooth_time = 2.0
min_extrude_temp = 170
heater_pin: PB15
sensor_type = NTC 100K MGB18-104F39050L32
sensor_pin: PC0
control: pid
pid_Kp: 22
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 325
# Heated BED
[heater_bed]
heater_pin: PB4
sensor_pin: PC0
control: watermark
min_temp: 0
max_temp: 130
control = pid
pid_kp = 73.064
pid_ki = 0.729
pid_kd = 1830.251
# FAN Control
#fan for printed model FAN0
[fan]
pin: PA13
#fan for hotend FAN1
#[heater_fan heatbreak_cooling_fan]
pin: PA14
shutdown_speed: 1
#fan for control board FAN2
[heater_fan my_control_fan]
pin: PB2
# MCU Serial number and Temp sensor
## Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_12345-if00
[temperature_sensor mcu_temp]
sensor_type = temperature_mcu
# Printer type and settings
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000 #Max 4000
max_accel_to_decel: 1500
square_corner_velocity: 5.0
max_z_velocity: 15 #Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 100
# TMC UART configuration
[tmc2209 stepper_x]
uart_pin: PE7
diag_pin: PB14`Preformatted text`
run_current: 0.6
stealthchop_threshold: 999999
[tmc2209 stepper_y]
uart_pin: PE15
diag_pin: PB13
run_current: 0.6
[tmc2209 stepper_z]
uart_pin: PD10
run_current: 0.6
[tmc2209 extruder]
uart_pin: PD7
run_current: 0.6
sense_resistor: 0.110
[tmc2209 stepper_z1]
uart_pin: PC14
run_current: 0.6
# BL TOUCH CONFIGURATION
[bltouch]
sensor_pin = ^PA0
control_pin = PA2
pin_move_time = 0.680
stow_on_each_sample = True
probe_with_touch_mode = False
pin_up_reports_not_triggered = True
pin_up_touch_mode_reports_triggered = True
x_offset = -42
y_offset = 12
speed = 5.0
samples = 1
sample_retract_dist = 5.0
lift_speed = 5.0
samples_result = average
samples_tolerance = 0.100
samples_tolerance_retries = 1
z_offset = 0.950
# BED MESH AND Z TILT
[bed_mesh]
speed = 90
horizontal_move_z = 10.0
mesh_min = 35, 35
mesh_max = 245, 270
probe_count = 8, 8
mesh_pps = 3, 3
algorithm = bicubic
bicubic_tension = 0.2
relative_reference_index = 12
fade_start = 0.4
fade_end = 10.0
[z_tilt]
z_positions = -55, 325
145, 145
points = 80, 270
270, 30
speed = 45
# ADXL345 AND IMPUT SHAPER
[resonance_tester]
accel_chip = adxl345
probe_points =
150,150,200
[input_shaper]
shaper_type = mzv
damping_ratio_x = 0.1
damping_ratio_y = 0.1
shaper_type_x = ei
shaper_freq_x = 45.8
shaper_type_y = zv
shaper_freq_y = 21.0
# RUNOUT SENSOR
[filament_switch_sensor RunoutSensor]
pause_on_runout = True
runout_gcode = PAUSE
insert_gcode = RESUME
switch_pin = !PA3
# HOMING X Y Z
[safe_z_home]
home_xy_position = 150, 150
speed = 55.0
z_hop = 10
z_hop_speed = 5.0
move_to_previous = False
# HEATER VERIFICATION
[verify_heater extruder]
max_error = 160
check_gain_time = 35
hysteresis = 5
heating_gain = 2
[verify_heater heater_bed bed]
max_error = 160
check_gain_time = 70
hysteresis = 5
heating_gain = 1
# RETRACTION
[firmware_retraction]
retract_length = 6
retract_speed = 60
unretract_extra_length = 2
unretract_speed = 10
# EXTRAS
[gcode_arcs]
resolution = 1.0
[virtual_sdcard]
path = ~/gcode_files
[display_status]
[endstop_phase]
[pause_resume]
recover_velocity = 50
# MACROS
[gcode_macro POWER_OFF_PRINTER]
gcode =
{action_call_remote_method("set_device_power",
device="Printer",
state="off")}
[delayed_gcode delayed_printer_off]
initial_duration = 0.
gcode =
{% if printer.idle_timeout.state == "Idle" %}
POWER_OFF_PRINTER
[gcode_macro UNLOAD_FILAMENT]
gcode =
{% set speed = params.SPEED|default(500) %}
G91
G1 E-50 F{speed}
G1 E-50 F{speed}
G92
[gcode_macro LOAD_FILAMENT]
gcode =
G91
G1 E50 F{speed}
G1 E50 F{speed}
G92
[gcode_macro START_PRINT]
gcode =
G90
SET_GCODE_OFFSET Z=0.0
G28
BED_MESH_PROFILE LOAD="default"
G1 X15 Y20 Z5 F6000
G1 Z0.15 F300
[gcode_macro END_PRINT]
gcode =
M140 S0
M104 S0
M106 S0
G91
G1 X-2 Y-2 E-3 F300
G1 Z20 F3000
G90
M84
[gcode_macro PAUSE]
description = Pause the actual running print
rename_existing = PAUSE_BASE
gcode =
PAUSE_BASE
_TOOLHEAD_PARK_PAUSE_CANCEL
[gcode_macro RESUME]
description = Resume the actual running print
rename_existing = RESUME_BASE
gcode =
{% set extrude = printer['gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL'].extrude %}
{% if 'VELOCITY' in params|upper %}
{% set get_params = ('VELOCITY=' + params.VELOCITY) %}
{%else %}
{% set get_params = "" %}
{% if printer.extruder.can_extrude|lower == 'true' %}
M83
G1 E{extrude} F2100
{% if printer.gcode_move.absolute_extrude |lower == 'true' %} M82 {% endif %}
{% else %}
{action_respond_info("Extruder not hot enough")}
RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description = Cancel the actual running print
rename_existing = CANCEL_PRINT_BASE
variable_park = True
gcode =
{% if printer.pause_resume.is_paused|lower == 'false' and park|lower == 'true'%}
TURN_OFF_HEATERS
CANCEL_PRINT_BASE
[gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL]
description = Helper: park toolhead used in PAUSE and CANCEL_PRINT
variable_extrude = 1.0
gcode =
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
{% set z_park_delta = 2.0 %}
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z < (max_z - z_park_delta) %}
{% set z_safe = z_park_delta %}
{% else %}
{% set z_safe = max_z - act_z %}
M83
G1 E-{extrude} F2100
{% else %}
{% if "xyz" in printer.toolhead.homed_axes %}
G91
G1 Z{z_safe} F900
G90
G1 X{x_park} Y{y_park} F6000
{% if printer.gcode_move.absolute_coordinates|lower == 'false' %} G91 {% endif %}
{% else %}
{action_respond_info("Printer not homed")}
[gcode_macro BED_MESH_CALIBRATE]
rename_existing = BASE_BED_MESH_CALIBRATE
gcode =
BED_MESH_CLEAR
G1 X125 Y125 Z5 F6000
[bed_mesh default]
