Print cancelled after prime line
Printer Model: Positron LT
MCU / Printerboard: Bigtreetech SKR Pico
Host / SBC: Raspberry Pi Zero W 2
klippy.log:
klippy.log (494.4 KB)
Everytime I sent a file to print, the printer do the hming sequence, bed leveling, then print a prime line and stop. Bed temperature and nozzle temperature stay hot for about 7 minutes, then the print cancel. Temperatures targets go to “0” and homing is lost. I am using Orca Slicer. I was printing fine, then I decided to change irprobe with a microprobe and start running into this issue. Had checked my configuration files over and over but have not been able to identify a posible reason. Any help will be really appreciated.
Hello @nausfaratu !
This the heater timeout. A safety feature of Klipper.
Exiting SD card print (position 6237)
Something is happening here.
Please attach a faulty gcode file to your next post.
BTW: Why do you have A START_PRINT macro and a PRINT_START macro when both do the exact same in the first two lines?
Not sure about the start print and print start macros. I don’t have much experience with klipper snd basically copied a configuration from someone else. Should I eliminate one of them then? Also, attached the gcode of the file I am trying to print.
Filter Support Holder_0.2mm_PLA_The Positron_18m37s.gcode.txt (523.3 KB)
