Printer object already created
I got an error while trying your solution
Code:
printer.cfg (9.7 KB)
Hello @hubertdungen !
klippy.log?
Please attach it to your next post.
This should explain itself:
grafik
[temperature_fan raspberry_pi]
pin: host:gpio211
kick_start_time: 0.8
#shutdown_speed: 0
off_below: 0.1
max_power: 1.0
#fan_speed: 0.6
sensor_type: temperature_host
control: pid
min_temp: 0
max_temp: 85
#max_delta: 5.0
pid_kp: 1.0
pid_ki: 0.5
pid_kd: 2.0
min_speed: 0.1
max_speed: 0.6
target_temp: 38
[temperature_sensor raspberry_pi]
min_temp: 10
max_temp: 100
Klipper does not allow using the same object for two different purposes. Comment out or delete the settings-block [temperature_sensor raspberry_pi]
I did that and it worked.
Thank you!
