Printer Shutting down while printing at random
Printer Model: Voron V0
MCU / Printerboard: BTT Manta M4P
Host / SBC: CB1
I’ve been trying just about everything to try and get a simple print out of my printer. I just upgraded to an EBB36 connected to my Manta M4P using the IO2CAN I’m having a problem where it randomly stops printing and won’t let me get into mainsail without power cycling the printer. I have checked all the power connections and they appear all fine I’ve checked all the crimps and fixed my CAN_H wire and that still didn’t fix it so I reinstalled Klipper on everything and that also didn’t fix it. So I replaced the EBB with a spare. I’ve made sure the baud rate is the same between both are is 500000. I’m also not really sure what the exact error msg is because I can’t see it before it kicks me out of mainsail. I have also tried turning off all unnecessary features like my bed and toolhead LEDs and aux and chamber fans. I also tried changing the psu incase it was drawing to much for the stock psu
klippy.log (4.6 MB)
moonraker.log (259.3 KB)
The problem, where you can’t access mainsail, is hard to debug by klippy logs.
Most probably it is a Linux issue, Network and/or sort of hardware.
About the only error that is present in this log.
Stats 1019.0: gcodein=0  mcu: mcu_awake=0.031 mcu_task_avg=0.000034 mcu_task_stddev=0.000042 bytes_write=2254186 bytes_read=395690 bytes_retransmit=9 bytes_invalid=0 send_seq=40494 receive_seq=40494 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=23 upcoming_bytes=807 freq=64000754
MCU 'mcu' shutdown: Missed scheduling of next digital out event
clocksync state: mcu_freq=64000000 last_clock=65488368732 clock_est=(990.799 63655920428 64000753.867) min_half_rtt=0.000085 min_rtt_time=320.436 time_avg=990.798(845.839) clock_avg=63655920428.736(54134322478.707) pred_variance=4065493.568
Dumping serial stats: bytes_write=2275596 bytes_read=598865 bytes_retransmit=9 bytes_invalid=0 send_seq=41795 receive_seq=41795 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0
Sent 94 2988.490621 2988.490621 16: seq: 1d, queue_digital_out oid=14 clock=2550270975 on_ticks=2935866
Sent 95 2989.390893 2989.390893 16: seq: 1e, queue_digital_out oid=14 clock=2607870976 on_ticks=2605660
Sent 96 2993.290568 2993.290568 16: seq: 1f, queue_digital_out oid=14 clock=2857470976 on_ticks=2975109
Sent 97 2994.190604 2994.190604 16: seq: 10, queue_digital_out oid=14 clock=2915070976 on_ticks=2348769
Sent 98 2994.490791 2994.490791 16: seq: 11, queue_digital_out oid=14 clock=2934270975 on_ticks=2752127
Sent 99 2998.690527 2998.690527 16: seq: 12, queue_digital_out oid=14 clock=3203070976 on_ticks=2704088
Receive: 94 3003.453039 2998.690527 14: seq: 13, stats count=158 sum=97315 sumsq=432977
Receive: 95 3003.490192 2998.690527 15: seq: 13, analog_in_state oid=13 next_clock=3509758976 value=23990
Receive: 96 3003.510142 2998.690527 14: seq: 13, analog_in_state oid=15 next_clock=3511038976 value=7850
Receive: 97 3003.790138 2998.690527 15: seq: 13, analog_in_state oid=13 next_clock=3528958976 value=23990
Receive: 98 3003.810126 2998.690527 14: seq: 13, analog_in_state oid=15 next_clock=3530238976 value=7846
Receive: 99 3003.991327 2998.690527 12: seq: 13, shutdown clock=3523071130 static_string_id=Missed scheduling of next digital out event
Hmmm,
Basically, by some reason, klippy does not send a new PWM in time.
I can’t spot anything suspicious.
I may only suggest to just update the Klipper host and CAN mcu and reproducing the issue.
Hope that helps.
They should have been up to date. But that hopefully doesn’t matter for the moment I finally went ahead and changed the CB1 out for one from another printer and had a successful dry print so now I’m going to try a full print
