Printer stuck on heating
Printer Model: CoreXY
MCU / Printerboard: MKS Gen_L V2.1
[stepper_x]
step_pin = PF0
dir_pin = !PF1
enable_pin = !PD7
microsteps = 64
rotation_distance = 40
endstop_pin = ^PE5
position_endstop = 0
position_max = 310
homing_speed = 50
[stepper_y]
step_pin = PF6
dir_pin = !PF7
enable_pin = !PF2
microsteps = 64
endstop_pin = ^PJ1
position_max = 310
homing_speed = 50
step_pin = PL3
dir_pin = PL1
enable_pin = !PK0
microsteps = 64
rotation_distance = 8
endstop_pin = ^PD3
position_endstop = 0.5
position_max = 300
step_pin: PA4
dir_pin: !PA6
enable_pin: !PA2
microsteps: 64
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB4
sensor_type: PT1000
sensor_pin: PK5
pullup_resistor: 4700
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 280
[heater_bed]
heater_pin = PH5
sensor_pin = PK6
control = watermark
min_temp = 0
max_temp = 130
[fan]
pin = PH6
serial = /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
[printer]
kinematics = corexy
max_velocity = 200
max_accel = 15000
max_z_velocity = 25
max_z_accel = 150
minimum_cruise_ratio = 0.5
square_corner_velocity = 5
[tmc2130 stepper_x]
cs_pin = PK1
driver_sgt = 5
spi_software_mosi_pin = PB2
spi_software_miso_pin = PB3
spi_software_sclk_pin = PB1
run_current = 1.1
stealthchop_threshold = 0
interpolate = False
[tmc2130 stepper_y]
cs_pin = PK2
driver_sgt = 5
run_current = 1.1
interpolate = False
[tmc2130 stepper_z]
cs_pin = PK3
driver_sgt = 5
run_current = 1.4
interpolate = False
[tmc2130 extruder]
cs_pin = PK4
driver_sgt = 5
run_current = 1.1
interpolate = False
[board_pins]
aliases =
EXP1_1=P1.31, EXP1_3=P0.18, EXP1_5=P0.15, EXP1_7=P1.0,  EXP1_9=<GND>,
EXP1_2=P1.30, EXP1_4=P0.16, EXP1_6=P0.17, EXP1_8=P1.22, EXP1_10=<5V>,
EXP2_1=P0.8, EXP2_3=P3.25, EXP2_5=P3.26, EXP2_7=P0.27, EXP2_9=<GND>,
EXP2_2=P0.7, EXP2_4=P0.28, EXP2_6=P0.9,  EXP2_8=<RST>, EXP2_10=<NC>
Extruder max_extrude_ratio=0.266081
mcu ‘mcu’: Starting serial connect
Loaded MCU ‘mcu’ 105 commands (v0.10.0-557-gf7e29b27-dirty-20220901_030356-mkspi / gcc: (GCC) 5.4.0 binutils: (GNU Binutils) 2.26.20160125)
MCU ‘mcu’ config: ADC_MAX=1023 BUS_PINS_spi=PB3,PB2,PB1 BUS_PINS_twi=PD0,PD1 CLOCK_FREQ=16000000 MCU=atmega2560 PWM_MAX=255 RECEIVE_WINDOW=192 RESERVE_PINS_serial=PE0,PE1 SERIAL_BAUD=250000 STATS_SUMSQ_BASE=256
Sending MCU ‘mcu’ printer configuration…
Configured MCU ‘mcu’ (610 moves)
Starting heater checks for heater_bed
TMC stepper_x failed to init: Unable to write tmc spi ‘stepper_x’ register CHOPCONF
TMC stepper_y failed to init: Unable to write tmc spi ‘stepper_y’ register CHOPCONF
TMC stepper_z failed to init: Unable to write tmc spi ‘stepper_z’ register CHOPCONF
TMC extruder failed to init: Unable to write tmc spi ‘extruder’ register CHOPCONF
Starting heater checks for extruder
Stats 17.4: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1566 bytes_read=4421 bytes_retransmit=9 bytes_invalid=6 send_seq=145 receive_seq=145 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16025155 heater_bed: target=0 temp=0.0 pwm=0.000 sysload=0.91 cputime=0.315 memavail=3803344 print_time=1.254 buffer_time=0.250 print_stall=0 extruder: target=0 temp=0.0 pwm=0.000
webhooks client 140732460778576: New connection
webhooks client 140732460778576: Client info {‘program’: ‘Moonraker’, ‘version’: ‘v0.9.3-0-g71f9e67’}
Stats 18.4: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1572 bytes_read=4436 bytes_retransmit=9 bytes_invalid=6 send_seq=146 receive_seq=146 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16007834 heater_bed: target=0 temp=0.0 pwm=0.000 sysload=0.91 cputime=0.317 memavail=3802496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=0.0 pwm=0.000
webhooks: registering remote method ‘shutdown_machine’ for connection id: 140732460778576
webhooks: registering remote method ‘reboot_machine’ for connection id: 140732460778576
webhooks: registering remote method ‘pause_job_queue’ for connection id: 140732460778576
webhooks: registering remote method ‘start_job_queue’ for connection id: 140732460778576
Stats 19.4: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1578 bytes_read=4529 bytes_retransmit=9 bytes_invalid=6 send_seq=147 receive_seq=147 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16002864 heater_bed: target=0 temp=20.1 pwm=0.000 sysload=0.91 cputime=0.320 memavail=3802496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=18.7 pwm=0.000
Stats 20.4: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1584 bytes_read=4635 bytes_retransmit=9 bytes_invalid=6 send_seq=148 receive_seq=148 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16001687 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.91 cputime=0.322 memavail=3801776 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=18.7 pwm=0.000
Stats 21.4: gcodein=0 mcu: mcu_awake=0.043 mcu_task_avg=0.000189 mcu_task_stddev=0.000326 bytes_write=1590 bytes_read=4756 bytes_retransmit=9 bytes_invalid=6 send_seq=149 receive_seq=149 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16001174 heater_bed: target=0 temp=20.4 pwm=0.000 sysload=0.91 cputime=0.327 memavail=3793760 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.6 pwm=0.000
Stats 22.4: gcodein=0 mcu: mcu_awake=0.043 mcu_task_avg=0.000189 mcu_task_stddev=0.000326 bytes_write=1596 bytes_read=4849 bytes_retransmit=9 bytes_invalid=6 send_seq=150 receive_seq=150 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000984 heater_bed: target=0 temp=20.3 pwm=0.000 sysload=0.91 cputime=0.330 memavail=3789856 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.2 pwm=0.000
Stats 23.4: gcodein=0 mcu: mcu_awake=0.043 mcu_task_avg=0.000189 mcu_task_stddev=0.000326 bytes_write=1602 bytes_read=4955 bytes_retransmit=9 bytes_invalid=6 send_seq=151 receive_seq=151 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000807 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.91 cputime=0.331 memavail=3796960 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=16.5 pwm=0.000
Stats 24.4: gcodein=0 mcu: mcu_awake=0.043 mcu_task_avg=0.000189 mcu_task_stddev=0.000326 bytes_write=1608 bytes_read=5061 bytes_retransmit=9 bytes_invalid=6 send_seq=152 receive_seq=152 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000684 heater_bed: target=0 temp=20.8 pwm=0.000 sysload=0.91 cputime=0.333 memavail=3798272 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=20.3 pwm=0.000
Stats 25.4: gcodein=0 mcu: mcu_awake=0.043 mcu_task_avg=0.000189 mcu_task_stddev=0.000326 bytes_write=1614 bytes_read=5154 bytes_retransmit=9 bytes_invalid=6 send_seq=153 receive_seq=153 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000591 heater_bed: target=0 temp=21.1 pwm=0.000 sysload=0.84 cputime=0.334 memavail=3799952 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.8 pwm=0.000
Stats 26.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1620 bytes_read=5273 bytes_retransmit=9 bytes_invalid=6 send_seq=154 receive_seq=154 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000475 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.84 cputime=0.336 memavail=3799232 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=21.2 pwm=0.000
Stats 27.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1626 bytes_read=5379 bytes_retransmit=9 bytes_invalid=6 send_seq=155 receive_seq=155 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000602 heater_bed: target=0 temp=20.3 pwm=0.000 sysload=0.84 cputime=0.339 memavail=3793088 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=24.5 pwm=0.000
Stats 28.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1632 bytes_read=5472 bytes_retransmit=9 bytes_invalid=6 send_seq=156 receive_seq=156 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000624 heater_bed: target=0 temp=20.8 pwm=0.000 sysload=0.84 cputime=0.340 memavail=3793088 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=25.0 pwm=0.000
Stats 29.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1638 bytes_read=5598 bytes_retransmit=9 bytes_invalid=6 send_seq=157 receive_seq=157 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000610 heater_bed: target=0 temp=20.8 pwm=0.000 sysload=0.84 cputime=0.342 memavail=3793824 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=28.6 pwm=0.000
Stats 30.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1644 bytes_read=5698 bytes_retransmit=9 bytes_invalid=6 send_seq=158 receive_seq=158 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000564 heater_bed: target=0 temp=20.5 pwm=0.000 sysload=0.77 cputime=0.344 memavail=3793824 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=30.6 pwm=0.000
Stats 31.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000074 mcu_task_stddev=0.000058 bytes_write=1650 bytes_read=5798 bytes_retransmit=9 bytes_invalid=6 send_seq=159 receive_seq=159 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000508 heater_bed: target=0 temp=21.1 pwm=0.000 sysload=0.77 cputime=0.345 memavail=3793824 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=31.1 pwm=0.000
Stats 32.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000077 mcu_task_stddev=0.000064 bytes_write=1656 bytes_read=5939 bytes_retransmit=9 bytes_invalid=6 send_seq=160 receive_seq=160 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000430 heater_bed: target=0 temp=19.9 pwm=0.000 sysload=0.77 cputime=0.347 memavail=3790240 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=38.6 pwm=0.000
Stats 33.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000077 mcu_task_stddev=0.000064 bytes_write=1662 bytes_read=6039 bytes_retransmit=9 bytes_invalid=6 send_seq=161 receive_seq=161 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000380 heater_bed: target=0 temp=19.9 pwm=0.000 sysload=0.77 cputime=0.350 memavail=3795072 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=39.1 pwm=0.000
Stats 34.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000077 mcu_task_stddev=0.000064 bytes_write=1668 bytes_read=6139 bytes_retransmit=9 bytes_invalid=6 send_seq=162 receive_seq=162 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000336 heater_bed: target=0 temp=20.4 pwm=0.000 sysload=0.77 cputime=0.351 memavail=3795664 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=42.1 pwm=0.000
Stats 35.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000077 mcu_task_stddev=0.000064 bytes_write=1674 bytes_read=6267 bytes_retransmit=9 bytes_invalid=6 send_seq=163 receive_seq=163 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000304 heater_bed: target=0 temp=20.2 pwm=0.000 sysload=0.71 cputime=0.353 memavail=3795792 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=43.0 pwm=0.000
Stats 36.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000077 mcu_task_stddev=0.000064 bytes_write=1680 bytes_read=6367 bytes_retransmit=9 bytes_invalid=6 send_seq=164 receive_seq=164 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000407 heater_bed: target=0 temp=20.3 pwm=0.000 sysload=0.71 cputime=0.354 memavail=3796976 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=46.3 pwm=0.000
Stats 37.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000066 bytes_write=1686 bytes_read=6480 bytes_retransmit=9 bytes_invalid=6 send_seq=165 receive_seq=165 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000463 heater_bed: target=0 temp=19.9 pwm=0.000 sysload=0.71 cputime=0.356 memavail=3797840 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=49.3 pwm=0.000
Stats 38.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000066 bytes_write=1692 bytes_read=6608 bytes_retransmit=9 bytes_invalid=6 send_seq=166 receive_seq=166 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000458 heater_bed: target=0 temp=20.2 pwm=0.000 sysload=0.71 cputime=0.359 memavail=3796864 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=52.9 pwm=0.000
Stats 39.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000066 bytes_write=1698 bytes_read=6708 bytes_retransmit=9 bytes_invalid=6 send_seq=167 receive_seq=167 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000516 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.71 cputime=0.361 memavail=3797968 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=54.3 pwm=0.000
Stats 40.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000066 bytes_write=1704 bytes_read=6808 bytes_retransmit=9 bytes_invalid=6 send_seq=168 receive_seq=168 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000547 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.65 cputime=0.362 memavail=3797744 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=56.6 pwm=0.000
Stats 41.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000066 bytes_write=1710 bytes_read=6936 bytes_retransmit=9 bytes_invalid=6 send_seq=169 receive_seq=169 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000562 heater_bed: target=0 temp=20.8 pwm=0.000 sysload=0.65 cputime=0.364 memavail=3797744 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=58.8 pwm=0.000
Stats 42.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1716 bytes_read=7049 bytes_retransmit=9 bytes_invalid=6 send_seq=170 receive_seq=170 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000558 heater_bed: target=0 temp=21.0 pwm=0.000 sysload=0.65 cputime=0.366 memavail=3799424 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=62.6 pwm=0.000
Stats 43.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1722 bytes_read=7149 bytes_retransmit=9 bytes_invalid=6 send_seq=171 receive_seq=171 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000540 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.65 cputime=0.368 memavail=3794864 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=64.0 pwm=0.000
Stats 44.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1728 bytes_read=7277 bytes_retransmit=9 bytes_invalid=6 send_seq=172 receive_seq=172 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000559 heater_bed: target=0 temp=20.6 pwm=0.000 sysload=0.65 cputime=0.370 memavail=3798496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.2 pwm=0.000
Stats 45.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1734 bytes_read=7377 bytes_retransmit=9 bytes_invalid=6 send_seq=173 receive_seq=173 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000575 heater_bed: target=0 temp=20.4 pwm=0.000 sysload=0.60 cputime=0.371 memavail=3798496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=69.6 pwm=0.000
Stats 46.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1740 bytes_read=7477 bytes_retransmit=9 bytes_invalid=6 send_seq=174 receive_seq=174 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000525 heater_bed: target=0 temp=20.3 pwm=0.000 sysload=0.60 cputime=0.372 memavail=3798496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=73.5 pwm=0.000
Stats 47.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1746 bytes_read=7618 bytes_retransmit=9 bytes_invalid=6 send_seq=175 receive_seq=175 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000482 heater_bed: target=0 temp=20.2 pwm=0.000 sysload=0.60 cputime=0.374 memavail=3798496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=74.9 pwm=0.000
Stats 48.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1752 bytes_read=7718 bytes_retransmit=9 bytes_invalid=6 send_seq=176 receive_seq=176 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000447 heater_bed: target=0 temp=20.3 pwm=0.000 sysload=0.60 cputime=0.375 memavail=3798496 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=75.4 pwm=0.000
Stats 49.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1758 bytes_read=7818 bytes_retransmit=9 bytes_invalid=6 send_seq=177 receive_seq=177 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000416 heater_bed: target=0 temp=20.4 pwm=0.000 sysload=0.60 cputime=0.377 memavail=3799952 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=79.1 pwm=0.000
Stats 50.4: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000080 mcu_task_stddev=0.000067 bytes_write=1764 bytes_read=7946 bytes_retransmit=9 bytes_invalid=6 send_seq=178 receive_seq=178 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=16000416 heater_bed: target=0 temp=21.0 pwm=0.000 sysload=0.55 cputime=0.379 memavail=3799952 print_time=1.254 buffer_time=0.000 print_stall=0 extruder: target=0 temp=83.0 pwm=0.000
Once i turn on the rapsberry and the power suply the heater starts heating, and never stops.
The heatbed is with a C-LIN SSR 40A480VAC Solid State Relay Input.
This only means that your MOSFET is dead and there is a leaking current, I can suggest replacing it or the board.
You can simply disconnect the board from the klipper and check the voltage on the heater.
Unconfigured boards should not provide voltage to pins (mosfet here often disconnects ground, not VIN line).
@rfp :
Next time please upload the klippy.log (as it was asked for) and/or other log code as file:
Upload
or use the Preformatted Text feature of the editor:
Format
Maybe i should get a new board?
Mks monster8 v2
https://a.aliexpress.com/_EHP4dJr
