Printers fighting for control
Printer Model: 2 ender 3
MCU / Printerboard:mini skr 3.0
Host / SBC cb1
…im trying to run both printers off of one host a cb1 and when i restart on the other turn it off the cb1
klippy (2).log (1.3 MB)
You only can run/control one printer with a single host instance.
If you want to run/control two printers, you need either another SBC or another instance of Klipper on an existing SBC. But I don’t know if that is possible with the CB1.
As indicated by @EddyMI3D, you will need two separate instances of Klipper and Moonraker. KIAUH can set this up for you.
In addition, you need to switch to specifying the serial connection “by-path” because the Ender boards use an invariant “by-id” designation, which will cause collisions. Obtain this with:
ls /dev/serial/by-path/*
