Probe triggered prior to movement
Printer Model:
MCU / Printerboard:
…can someone tell me what i have wrong here
[gcode_macro PROBE_DOWN]
SET_PIN PIN=probe_enable VALUE=1
[gcode_macro PROBE_UP]
SET_PIN PIN=probe_enable VALUE=0
[output_pin probe_enable]
pin: PA1 # Set to the control pin on your board
value: 0
[probe]
pin: ^PC14 # NOTE FOR V2 users: Set this to ^!PC14 to set the low level trigger
deactivate_on_each_sample: False
x_offset: -40
y_offset: -35
z_offset: 0 # Will be overridden when you do a PROBE_CALIBRATE
samples: 2
samples_tolerance: 0.05
samples_tolerance_retries: 3
activate_gcode:
PROBE_DOWN
G4 P500
deactivate_gcode:
PROBE_UP
[screws_tilt_adjust]
screw1: 30,35
screw1_name: Left-Front
screw2: 200,35
screw2_name: Right-Front
screw3: 200,205
screw3_name: Right-Back
screw4: 30,205
screw4_name: Left-Back
speed: 100
horizontal_move_z: 1
screw_thread: CW-M3
Hello @ten57 !
Please note:
When posting code snippets, please use the Preformatted Text feature of the editor, else important information get lost.
Format
In all, more information is helpful.
  • What printer (asked above)
  • What mainboard (asked above)
  • klippy.log (asked above)
  • What probe
