Printer Model: Funmat HT - Using Euclid style detachable probe
MCU / Printerboard: Bigtreetech Manta E3EZ with CB1 (Minimal v2.3.2 image / Debian 11)
klippy.log (731.8 KB)
I have gutted the stock Funmat HT printer and installed new hotend (E3D Volcano) and replaced the stock MCU with a Bigtreetech Manta E3EZ with CB1. The Z axis motor uses a ballscrew and I verified the rotation distance with digital calipers. I used the latest v2.3.2 minimal image which is Debian 11. Klipper / Moonraker / Mainsail installed with KIAUH and all are up to date as of writing this post.
The original printer only had manual bed leveling so I added a probe. Originally this was an old Creality capacitive probe but I was getting bad bed mesh results. I switched it out for a Euclid style magnetic detachable probe (using an Omron D2F-5 plunger microswitch).
It seems that when I run a PROBE_ACCURACY test each sample is roughly 0.1mm higher tan the prior sample. Homing Z axis resets this increase.
SCREWS_TILT_CALCULATE probes all 3 screw locations without this 0.1mm increase. But running it again introduces the increase. Homing Z in between running the command twice yields probe points on the same heights.
When doing a 5x5 bed mesh the initial probe is at 2.965 and last probe is at 4.90375
Have manually verified the bed is level with the gantry with a BED_SCREWS_ADJUST.
Just need a sanity check. It was doing this before the recent Klipper commits with bed_mesh modifications.
