I prepared a klipper config for the Prusa MK2s with an LCD interface similar to the Original Prusa Firmware (the original klipper LCD menu is terrible).
The configuration has been split into different files to keep it clean and readable (main printer.cfg, mk2s harware folder, custom menu and macro folder).
Most features are included (M600, M601, M300, Mesh Bed Leveling…, Remainig Time), Linear Advance has ben replaced with klipper Pressure Advance and will require tuning probably…).
The main missing feature is the XYZ Calibration, which is non trivial to implement.
General cleanup and Optional Features (added 09/09/2022):
to be enabled by uncommenting (deleting the #) in the file printer.cfg
#[include config/custom/menu_autoload.cfg] → creates autoload/unload filament entries in the Preheat menu (macro to automatically heat to a certain temperature, load/unload the filament, then cooldown)
#[include config/custom/macro_cold_pull.cfg] → creates automatical Coldpull entry in the Preheat Menu (preheat to selectable temperature [default 85°C for PLA], then automatically coldpull using the motor, no hand pull required, it works very well for PLA at 85 °C, beep at the end to alert the user [remember to pull the lever on the extruder to extract the filament after the automatic coldpull])
#[include config/custom/filament_diameter.cfg] → enable the “correct filament diameter” feature in the Tune menu, to change the filament diameter during printing, use the
M404 W{filament_diameter[0]};
command in the start GCODE to let Klipper know the filament diameter initially used in the slicer, then you can change the filament diameter on the flight while printing (for example if you use a different spool of filament)
#[include config/custom/accelerometer.cfg] → config for Raspberry Pi with adxl345 accelerometer for resonance testing (input shaper calibration)
added First Layer Calibration to the Calibration Menu (enabled by default)
Wanted to add a comment. I went through and set this up on Mainsail. After some troubleshooting, I ran into a few errors during the setup.
(I believe this might have been caused from newer version requirements after this config was built. Also, Mithrandil might have made this change on purpose or it was a typo, not certain. Either way, fluidd\mainsail would not agree with me it until this was done. In the printer.cfg file, uncomment z_offset: 0.70.
Modify the following file: config/mk2s/steppers.cfg file.
line 66 and line 82. remove static_ from both of these places. it should read just value:540.0
virtual gcode location. make sure to set the virtual gcode location (i did this in mainsail. fluidd might not have this issue) in printer.cfg and mainsail.cfg.
default path: ~/gcode_files
I had to set it to: ~/printer_data/gcodes
These three changes brought the printer online and im now able to run klipper on my mk2s. mini rambo firmware flashing is a breeze. one thing to keep in mind. the mini rambo requires 12v at the main connector in order to flash the firmware on the board. there is no usb pass through voltage for the mcu.
I understand this is probably day 1 stuff to a lot of users. I am fairly new to klipper, thought id save another new user some of the debugging i had to go through.
Mithrandil thank you very much for the hard work you put into building this. The lcd menu layout is so close to the original prusa interface, i can barely tell the difference. well done. well done.
