Printer Model: Voron 2.4 style (JennyPrinter CoreXY)
MCU / Printerboard: MKS Monster8 V2
klippy (5).log (799.7 KB)
So I have a laundry list of things I have tried to get this to work, but I’ll try to summarize directly to the issue.
Setup:
- JennyPrinter CoreXY (Voron 2 style kinematics)
- Z-max endstops for each Z motor (to fix gantry sag on startup, unavoidable)
- Elucid (klickly) Probe
- HermitCrab CAN toolhead (Baud rate @ 460800, timeout set to 0.050)
Slicer:
- Start GCode: G28, QUAD_GANTRY_LEVEL, BED_Mesh_ Profile Load=Full (Also tried bed BED_MESH_CALIBRATE, but does not work, see below)
Issue:
So from power on, the printer does a homing override:
- Y
- X
- level the gantry at max endstops
- Probe Z0, then sets z-offset with a G92 command.
Then I do a QGL to level the gantry accurately to the bed (Best I can get is a 0.020 set range) and ends up usually around 0.017mm. Then I did a BED_MESH_CALIBRATE, and then modified the offset of the med mesh with the offset of Z-max to bed position (necessary for zmax endstops and not having a perfect height from heatbed).
Upon print start (with the previous leveling steps done), a large perimeter skirt is CONSISTENTLY off from the left side of the bed to the right side of the bed. I manually measured multiple prints, and left side first layer height is 0.25-0.27mm, but right side is 0.45-0.47mm. First layer height is to be 0.30mm (0.6mm nozzle).
Left side of print bed first layer:
Right side of print bed first layer:
I am at a loss, it seems like the QGL and BED_MESH first layer results are identical, but I can feel the Z-motors adjusting to the Bed Mesh, so I do know it is “following” the bed mesh.
Any ideas as to why there is a constant skew to the gantry even after all the leveling is completed?
printer.cfg (13.3 KB)
HermitCrab_Canbus_pins.cfg (1.5 KB)
Elucid.cfg (8.6 KB)
I uploaded my configs incase someone sees an issue. I do not have a log currently but I can get one if requested.
Note, in the printer.cfg the “Full” Bed Mesh had to be modified manually to account for the probe offset when probing for Z0. I did a BED_MESH_CALIBRATE and subtracted(added) the z-offset to the values to get true bed height. This was necessary as it was crashing the nozzle into the bed going to Z-5.952mm instead of Z0.
Example:
Z=20mm after G28 command: Z=20mm
Z=20 after BED_MESH_CALIBRATE: Z=25.592mm
