Printer Model: voron 2.4
hELLO
After a “bed_mesh_calibrate” I have too many “quad_gantry” errors (5 loops in quad_gantry subroutine); i must do quad_gentry 2 or 3 times to get good value.
The speed option in QGL is how fast the print head moves between probe points, not how fast the probing is done. Changing this value to 5 will not improve accuracy, and will only make for a painfully slow QGL process.
It sounds like you’re doing the mesh before the QGL if I understood your post. This is the wrong order. You need to run QGL without any mesh loaded, and then create the mesh after QGL is complete.
