Raspberry Pi 4 4GB 7" Screen Not Rotating!
Printer Model: CR10-S
MCU / Printerboard: ?
klippy.log n/a
Hello again! I am running Mainsail and am having trouble rotating my 7" touchscreen display. I have tried editing the /boot/config.txt by inserting “lcd_rotate=2”, as the screen needs to be rotated 180 degrees. Nothing has worked. At one point, as it was booting up it was rotated properly, but as it finished booting, it went back to being upside down. I also have tried commenting “dtoverlay=vc4-fkms-v3d”, but that didn’t work either. I have successfully rotated this same setup by using the the “lcd_rotate=2” method on another SD card. Any thoughts?
Never mind! I commented the line below “dtoverlay=vc4-fkms-v3d” and that fixed it!
