Raspberry Pi 4 Model B + Duet 3 6 HC
Hello everyone,
I have made the connections between the Raspberry Pi 4 Model B and the Duet 3 6HC board, but the serial port /dev/ttyACM0 does not appear. Am I making the connections incorrectly? Can someone who is knowledgeable in this area help me? Because of this, I am getting the following error:
“mcu ‘mcu’: Unable to connect Once the underlying issue is corrected, use the ‘FIRMWARE_RESTART’ command to reset the firmware, reload the config, and restart the host software. Error configuring printer”
Please do not always delete the template. Stick to it.
Please attach the klippy.log to your next post.
Can you share the connection diagram between Raspberry Pi and Duet 3 6HC with me? How should I do it?
I am using the Duet 3 6HC v1.01 motherboard. I want to control the Duet 3 6HC + 3HC boards through Klipper using a Raspberry Pi 4 Model B. Can you help me with the connection diagrams and make menuconfig configurations?"
Duet 3 6HC Wiring Diagram
@koconnor help please !!!
You may have a look here:
And also here:
Thanks @EddyMI3D
I will review these.
I looked but couldn’t find anything about Raspberry and Duet 3 6HC connection cables. Do I need to connect it with TX and RX pins? Can someone who knows this help me?
A USB A to micro USB cable
@EddyMI3D Thank you very much, I solved it, as you said, it communicated with the MCU via USB and microUSB cable.
I have another issue that needs to be resolved now :frowning:
I solved this. If I have any other problems, I will write here again. Thank you all for everything.
