Sorry about the comment regarding the power supplies. I didn’t follow through on the schematic properly (did I say something about turning it 90 degrees so it can be read easily on the github page?).
I must take issue with your statement claiming that the TPS2006 “effectively handling potential ground loop issues”. If you’re plugging in a USB C J64 to the power connector on a Raspberry Pi and USB C J34 to the power port - you definitely have a ground loop through the cables’ shield and probably the ground connection.
I don’t know what you’re electronic board manufacturing experience is - I personally have 30+ years with a bit of aerospace. I’m not sure you’re getting that the BoM and soldering operations are only part of the cost during volume production and a small percentage of the cost during prototyping.
When I said $500 per board for initial builds, I’m including costs for placement machine programming, stencils, temporary pass through line setup setup, temperature profiling and so on. Along with that, you have a lot of hand placed parts (I’m presuming all those connectors are PTH) that will require somebody to write instructions for the placement operators and have a designer sit through the initial builds to make sure that everything is correct (If you’re board stuffer is not local, then plan for travel expenses). Don’t forget you need to arrange and pay for storage for the parts before assembly (none of which will arrive at the same times as any of the others). Before you start assembling the boards, you’re going to need to load firmware onto the MCUs. You also need boxes, ESD bags, parts bags for the various locking connectors that are non-standard.
You’ll also need business insurance, an accountant with software resources to set up the company as well as the payment system/CRM - you can sell on Amazon or Ebay without this but if you want a distributor to sell the boards, you’re going to have to have a company that they can work with electronically, can see that you’re insured so they can pass any potential problems onto you and know that their money won’t primarily go to paying for that Ferrari you’ve always wanted.
Once you get that stuff set up with some prototypes to show customers/distributors/thought leaders along with a company they can work with and have confidence in, then you can expect orders which will drive down your costs as you do follow on builds. Regardless, I still think you’re being overly aggressive in what you think your costs are and not seeing the big picture with all the work and out of pocket expenses you have in front of you.
Finally, you didn’t address my last point. What makes this board special and would entice somebody to buy it? I listed five boards, all of which are well known with good community support, are sub $100 with drivers, work well with Klipper and some of them, like the Manta M5P, have features that make people get excited about using it in a printer.
You’re emphasizing reliability and good engineering, but when I look at your board:
That doesn’t come through.
What I do see is a hell of a lot of connectors - at least twice as many as on the Robin Nano V3 and Manta M5P I have sitting in front of me. I don’t immediately see the value of all those connectors - if I have a printer that requires five steppers, it’s probably going to be a bed slinger with with two Z axis steppers for Z-Tilt. There are 'way too many options built in here for that type of application.
Along with the apparent complexity, I don’t see the advantage of the locking connectors for the power in and heater outputs. What I see is that you’ve replaced the need for me to put a ferrule on each line and shove it into a screw terminal block with having to crimp on a custom connector. You’re locking me into this board (pun intended) and that’s not a feature I’m willing to pay for.
If I can give you any kind of advice on the product: it is start small with a single, well defined use case with a feature that will catch people’s eyes and make them consider buying the product. Don’t try to meet the needs of everyone and every printer type; design for a specific type of customer with one use case.
Sorry for dumping all this on you I can see you’ve done a lot of work but I don’t think you understand that it’s a fraction of the work that you have in front of you. I do admire what you’re trying to do but i think you need to really take a hard look at what it’s going to cost you and what it will take you to break even. I would suggest talking to somebody local that is involved in electronics design, manufacturing and distribution to review your plans and give you advice - depending on where you are, there may be a government funded industry development organization that you can reach out ot.
