Printer Model: Ender 3 V2
MCU / Printerboard: Stock Creality 4.2.2 + Raspberry Pi 3B
klippy.log (507.1 KB)
(This issue has been resolved)
My raspberry pi 3b keeps getting an under-voltage warning, even when I’m just homing the printer. The lights on the Pi also blink at random intervals when the warning comes on.
The Pi is powered by a buck converter attached to the stock Ender 3V2 24v Power supply. The buck converter is set to lower the voltage to 5.25v, the maximum recommended voltage for a Pi. Along with running Mainsail, the Pi also has a 480p 15fps USB webcam and is hooked up to an Obico server to monitor remotely. The weirdest part is after monitoring the voltage constantly after hooking up my multimeter, the buck converter is constantly delivering 5.25 even while there is still an active under-voltage warning (as shown in the photos). Also, I did confirm that there is no warning when powering the Pi with a 5V CanaKit wall power adapter.
I have googled and looked through many forums, but I don’t see anyone with a similar problem. Does anyone have a solution for this? If not I think I’ll have to stick with powering the Pi separate from the printer.
Thanks in advance.
