MCU Shutdown at Same Point On Multiple Attempts
Printer Model: Ender 3 V2 NEO
MCU / Printerboard: Stock 4.2.2 Board
Host / SBC: RPI 3B+
klippy.zip (1.1 MB)
I was printing a Benchy, but the print has stopped in about the same spot (the extruder stopped less than a centimeter apart from the previous attempts), With an MCU error, and Klipper shuts down. after a firmware restart, the MCU is still down, requiring a reboot of the printer to function again. The printer and the Pi share the same power strip, and the Pi is saying it is being undervolted with a 2A charger, unsure if either of these would cause the issue shown in the logs. Let me know if more info is needed!
https://klipper.discourse.group/search?q=Lost%20communication%20with%20MCU%20mcu
I printed a 20mm Calibration Cube and it didn’t stop at all, maybe its something in my g code causing the pi to crash while its undervolted?
Sorry, apparently I just skipped over this piece of information: An undervolt condition or unstable power supplies are generally not an acceptable condition and need to be fixed.
The Pi3 needs at least 2.5A at 5.1V
Also, a charger is no power supply. Chargers are not stable enough.
@D86592 This is causing your problems.
Thanks everyone, ordered a Pi official power supply, will update the post if the issue stands!
