Resonance HW only works after 1st attempt
Printer Model: Tevo Tornado / Wanhao i3
MCU / Printerboard: MKS Gen L V2.1
Host / SBC: RPI4
klippy.zip (2.9 MB)
I have on both my printers two BTT S2DW (one for X, one for Y) They are permanently installed so that I don’t need to fiddle every time I want to do a test.
So, this is happening on both printers so I am assuming it’s a bug or perhaps I have something configured incorrectly.
When I go to do my Resonance Testing, it fails the first time I run the command, the 2nd time it works great, then it goes to try and do Y, same thing. It goes though X just fine but the first time it attempts to start Y it fails.
If I run it again, both axis will work perfectly.
What have I done wrong?
D
The attached log does not seem to contain any such event or I missed it.
Sorry for the late reply.
I just tried it again after doing a complete re-wire of the printer just in case it was a physical issue.
This is the error in the Console
Invalid lis2dw id (got ff vs 44).
4:03 PM
This is generally indicative of connection problems
(e.g. faulty wiring) or a faulty lis2dw chip.
I attached a log that I captured right after the operation I did.
klippy.zip (1.4 MB)
It’s weird that it errors on first run of each axis, then, if you run it a 2nd time, it works.
D
This is indeed strange.
In fact there had been an issue with SPI connected hardware on RP2040 boards that would cause such issues, but:
  • This issue was only affecting hardware SPI but not software SPI
  • Has been resolved quite a while ago
Not sure what could be causing this issue. If I find the time, I’ll try with an RP2040 based LIS2DW board on my side.
