Video showing the glitch.
(VNC and video stream are very laggy).
Don’t take it too seriously. This is stress testing. Not even sure that ATTACH_PROBE + PROBE + DETACH_PROBE are intended to be used this way. When using just the PROBE command alone, it always attaches the probe, goes back to its previous location, probes, docks and finally returns where it was in the first place.
The configuration code, with all the RESPONDs. If you want some more, just tell me, I’ll test.
# Dockable_Probe.cfg
#___________________________________________________________________
[delayed_gcode autorun]
;description: poor man's "Configuration.h"
initial_duration: 1
SAVE_VARIABLE VARIABLE=x_probe VALUE={317} ; countersunk scew X ccordinate
SAVE_VARIABLE VARIABLE=verbose_dockable_probe VALUE=True
SAVE_VARIABLE VARIABLE=verbose_type VALUE='"echo"'
; https://github.com/TypQxQ/KnobProbe_Klipper
[knobprobe]
pin: !P1.27 ; SKR 1.4 Z- STOP
deactivate_on_each_sample: False
z_offset: 0.0
speed: 5 ; /!\ 10 too fast for good repeatability, unlike bltouch
sample_retract_dist: 2.0
lift_speed: 100 ;5
; zero retries when setting 'samples_tolerance' to 0.01 -> 1 is enough
;samples_tolerance: 0.01 ; 100% success
samples: 1
;samples_tolerance_retries: 2
[gcode_macro KNOBPROBE_ACCURACY]
description: KnobProbe Z-height accuracy at dock position, and return to previous position
{% set pos = printer.gcode_move.gcode_position %}
{% set lift_speed = printer.configfile.settings.dockable_probe.lift_speed | float %} ; mm/s
{% set travel_speed = printer.configfile.settings.dockable_probe.travel_speed | float %} ; mm/s
MOVE_TO_EXTRACT_PROBE
PROBE_KNOBACCURACY {rawparams}
DETACH_PROBE
SAVE_GCODE_STATE NAME=state_KNOBPROBE_ACCURACY
G90
G0 Z{pos.z} F{60 * lift_speed}
G0 X{pos.x} Y{pos.y} F{60 * travel_speed}
RESTORE_GCODE_STATE NAME=state_KNOBPROBE_ACCURACY
[dockable_probe]
pin: ^P0.10 ; SKR 1.4 BLTouch probe pin ; NC switch
dock_sense_pin: !P1.0 ; SKR 1.4 Z+ STOP / PwrDet
;probe_sense_pin: !P2.0 ; SKR 1.4 BLTouch servo out
x_offset: -1.84
y_offset: 20.84
z_offset: 2.55 ; increasing value lowers the nozzle
approach_position: 327.5, 150.0, 15.0 ; z also for lifting before probing the coountersunk screw
dock_position: 327.5, 150.0
detach_position: 290.0, 150.0, 1.0 ; wipe left @ Z = 1 mm
z_hop: 15.0 ; also used before probing countersunk screw reference
speed: 5 ; probing speed ; /!\ 10 too fast for good repeatability, unlike bltouch
lift_speed: 100.0 ; 50.0 ;15.0 ; default = speed
attach_speed: 150.0 ; speed for MOVE_TO_DOCK_PROBE
detach_speed: 150.0 ; speed for MOVE_TO_DETACH_PROBE
travel_speed: 150.0 ; speed for MOVE_TO_APPROACH_PROBE
; zero retries when setting 'samples_tolerance' to 0.01 -> 1 sample is enough
samples: 1 ; default = 1
sample_retract_dist: 2.0 ; default = 2.0
;samples_result: average
check_open_attach: True
dock_retries: 0 ; not relevant
[gcode_macro MOVE_TO_APPROACH_PROBE]
description: Move close to the probe dock before attaching
rename_existing: MOVE_TO_APPROACH_PROBE_BASE
{% if printer.save_variables.variables.verbose_dockable_probe == True %}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="MOVE_TO_APPROACH_PROBE (overridden)"
{% set x_approach, y_dummy, z_dummy = printer.configfile.settings.dockable_probe.approach_position.replace(' ', '').split(',') %}
{% set z_speed = printer.configfile.settings.dockable_probe.attach_speed | float %} ; mm/s
{% set x_dummy, y_dummy, z_detach = printer.configfile.settings.dockable_probe.detach_position.replace(' ', '').split(',') %}
{% set z_hop = printer.configfile.settings.dockable_probe.z_hop | float %} ; mm/s
SAVE_GCODE_STATE NAME=state_MOVE_TO_APPROACH_PROBE
G90
G0 Z{z_hop} F{60 * z_speed}
G0 X{x_approach} F{60 * travel_speed}
G0 Z{z_detach} F{60 * z_speed}
RESTORE_GCODE_STATE NAME=state_MOVE_TO_APPROACH_PROBE
[gcode_macro MOVE_TO_INSERT_PROBE]
description: Move near the dock with the probe attached before detaching. Default : alias for MOVE_TO_APPROACH_PROBE
rename_existing: MOVE_TO_INSERT_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="MOVE_TO_INSERT_PROBE (overridden)"
SAVE_GCODE_STATE NAME=state_MOVE_TO_INSERT_PROBE
G90
RESTORE_GCODE_STATE NAME=state_MOVE_TO_INSERT_PROBE
[gcode_macro ATTACH_PROBE]
description: Check probe status and attach probe using the movement gcodes
rename_existing: ATTACH_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="ATTACH_PROBE (overridden)"
ATTACH_PROBE_BASE
SAVE_GCODE_STATE NAME=state_ATTACH_PROBE
G90
RESTORE_GCODE_STATE NAME=state_ATTACH_PROBE
[gcode_macro DETACH_PROBE]
description: Check probe status and detach probe using the movement gcodes
rename_existing: DETACH_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="DETACH_PROBE (default)"
DETACH_PROBE_BASE
[gcode_macro MOVE_TO_DOCK_PROBE]
description: Move to connect the toolhead/dock to the probe"
rename_existing: MOVE_TO_DOCK_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="MOVE_TO_DOCK_PROBE (default)"
[gcode_macro MOVE_TO_EXTRACT_PROBE]
description: Move away from the dock with the probe attached. Default : alias for MOVE_TO_APPROACH_PROBE.
rename_existing: MOVE_TO_EXTRACT_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="MOVE_TO_EXTRACT_PROBE (default)"
[gcode_macro MOVE_TO_DETACH_PROBE]
description: Move away from the dock to detach the probe
rename_existing: MOVE_TO_DETACH_PROBE_BASE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="MOVE_TO_DETACH_PROBE (default)"
[homing_override]
; parameters :
; X, Y, Z (separated with a blank space)
; M : performs a bed leveling after homing : saves detach + reattach moves
axes: xyz
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="G28 : start"
; parameters ; TODO : XY if instead of X Y
{% set _X_ = params.X|default("false") %}
{% set _Y_ = params.Y|default("false") %}
{% set _Z_ = params.Z|default("false") %}
{% set _O_ = params.O|default("false") %}
{% set _M_ = params.M|default("false") %}
{% set _XY_ = "false" %} ; workaround : G28 X Y sets Z to true ; we need to fix this !
; RESPOND MSG="_X_ : "{_X_}
; RESPOND MSG="_Y_ : "{_Y_}
; RESPOND MSG="_Z_ : "{_Z_}
; RESPOND MSG="_O_ : "{_O_}
; RESPOND MSG="_XY_ : "{_XY_}
{% if _X_ != "false" %} {% set _X_ = "true" %} {% endif %}
{% if _Y_ != "false" %} {% set _Y_ = "true" %} {% endif %}
{% if _Z_ != "false" %} {% set _Z_ = "true" %} {% endif %}
{% if _O_ != "false" %} {% set _O_ = "true" %} {% endif %}
{% if _M_ != "false" %} {% set _M_ = "true" %} {% endif %}
; G28 XY
{% if _X_ == "true" and _Y_ == "true" and _Z_ == "true" %}
{% set _XY_ = "true" %}
; G28 = G28 XYZ
{% if _X_ == "false" and _Y_ == "false" and _Z_ == "false" %}
{% set _XY_= "true" %}
{% if'x' in printer.toolhead.homed_axes %}
{% set _X_is_homed = "true" %}
{% else %}
{% set _X_is_homed = "false" %}
{% if'y' in printer.toolhead.homed_axes %}
{% set _Y_is_homed = "true" %}
{% else %}
{% set _Y_is_homed = "false" %}
{% if'z' in printer.toolhead.homed_axes %}
{% set _Z_is_homed = "true" %}
{% else %}
{% set _Z_is_homed = "false" %}
; defined in startup delayed macro (see printer.cfg) ; stored in variables.cfg
; = dockable_probe position for reference Z offset (countersunk screw)
{% set x_probe = printer.save_variables.variables.x_probe | float %}
; printer settings
{% set x_bed_center, y_bed_center = printer.configfile.config.bed_mesh.zero_reference_position.replace(' ', '').split(',') %}
{% set z_max = printer.configfile.config.stepper_z.position_max | float %}
{% set lift_accel = printer.configfile.config.printer.max_z_accel | float %} ; mm/s²
; dockable_probe settings
{% set travel_speed = printer.configfile.config.dockable_probe.travel_speed | float %} ; mm/s
{% set lift_speed = printer.configfile.config.dockable_probe.lift_speed | float %} ; mm/s
{% set x_knobprobe, y_dummy = printer.configfile.config.dockable_probe.dock_position.replace(' ', '').split(',') %}
SB_STATUS_HOMING ; Neopixel Stealthburner
{% if _X_ == "true" or _Y_ == "true" or _Z_ == true %}
FORCE_MOVE STEPPER=stepper_z DISTANCE={z_hop} VELOCITY={lift_speed} ACCEL={lift_accel} ; lift z, mm/s, mm/s²
; individual homings ; TODO : 'O' flag
{% if _X_ == "true" %}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Homing X..."
G28 X
{% if _Y_ == "true" %}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Homing Y..."
G28 Y
; Z calibration, auto Z offset, home Z, optional bed mesh
{% if _Z_ == "true" %}
SB_STATUS_CALIBRATING_Z ; Neopixel Stealthburner
RESPOND MSG="Attaching probe and calibrating Z offset..."
SAVE_GCODE_STATE NAME=state_G28
SET_DOCKABLE_PROBE AUTO_ATTACH_DETACH=0
; probe is attached while knobprobing (probing nozzle)
G90 ; absolute
G0 X{x_knobprobe} F{60 * travel_speed} ; KnobProbe position
{% set z_kinpos = z_max - z_hop - 10 %}
SET_KINEMATIC_POSITION Z={z_kinpos} ; gives "headroom" when moving the head down
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Attach probe while getting Z nozzle position :"
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="KNOBPROBE SAMPLES=3 SAMPLE_RETRACT_DIST=2"
KNOBPROBE SAMPLES=3 SAMPLE_RETRACT_DIST=2 ; attaches the Klicky probe + gets nozzle position : 1st reference
; probe reference spot
G91 ; relative
G0 Z{z_hop} F{60 * lift_speed} ; lift
G90 ; absolute
G0 X{x_probe} F{60 * travel_speed} ; probe is attached, align with countersunk screw
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Get Z countersunk screw position :"
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="PROBE SAMPLES=3 SAMPLE_RETRACT_DIST=2"
PROBE SAMPLES=3 SAMPLE_RETRACT_DIST=2 ; get Klicky position against countersunk screw : 2nd reference
_SAVE_GCODE_OFFSET ; auto Z offset
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Homing Z..."
; reset Z, move to center, home Z
SET_KINEMATIC_POSITION Z=0
G91 ; relative
G90 ; absolute
G0 X{x_bed_center} Y{y_bed_center} F{60 * travel_speed} ; bed center
RESTORE_GCODE_STATE NAME=state_G28
G28 Z
; bed mesh
{% if _M_ == "true" and _X_ == "true" and _Y_ == "true" and _Z_ == "true" %}
SB_STATUS_MESHING ; Neopixel Stealthburner
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Meshing..."
BED_MESH_CALIBRATE
; end
DETACH_PROBE
SET_DOCKABLE_PROBE AUTO_ATTACH_DETACH=1
SB_STATUS_READY ; Neopixel Stealthburner
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="G28 : end"
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="Ready..."
[gcode_macro BED_MESH_CALIBRATE]
description: Perform Mesh Bed Leveling
rename_existing: BASE_BED_MESH_CALIBRATE
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="BED_MESH_CALIBRATE"
ATTACH_PROBE
[gcode_macro AUTO_GCODE_OFFSET]
description: To be inserted in the start gcode, after G28, before first move
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="AUTO_GCODE_OFFSET"
{% set gcode_offset = printer.save_variables.variables.gcode_offset | float %}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="AUTO GCODE OFFSET : SET_GCODE_OFFSET Z="{gcode_offset}
SET_GCODE_OFFSET Z={gcode_offset}
[gcode_macro SET_REF_Z_OFFSET]
description: Save reference delta Z after calibration
; calls G28 and saves delta_z as ref_delta_z ; /!\ DO *NOT* REFACTORIZE /!\
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="SET_REF_Z_OFFSET"
SAVE_VARIABLE VARIABLE=ref_delta_z VALUE={3.14159265358979323846} ; dummy ref_delta_z = flag
G28 ; G28 will automatically reset ref_delta_z
[gcode_macro _SAVE_GCODE_OFFSET]
description: Calculates and save the gcode offset given reference delta Z and current delta Z
; called by G28 ; /!\ DO *NOT* REFACTORIZE /!\
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="_SAVE_GCODE_OFFSET"
{% set ref_delta_z = printer.save_variables.variables.ref_delta_z | default(3.14159265358979323846) | float %}
{% if ref_delta_z == 3.14159265358979323846 %} ; flag : ref_delta_z == pi : not initialized
_SAVE_REF_DELTA_Z ; save the the difference between KNOBPROBE and PROBE
_SAVE_CUR_DELTA_Z ; save the the difference between KNOBPROBE and PROBE
_CALC_GCODE_OFFSET ; calculate and save the gcode offset ( = reference delta_z - current delta_z)
[gcode_macro _SAVE_REF_DELTA_Z]
description: Save nozzle delta Z as reference offset
; called by _SAVE_GCODE_OFFSET ; /!\ DO *NOT* REFACTORIZE /!\
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".._SAVE_REF_DELTA_Z"
{% set probe_z = printer.probe.last_z_result %} ; ABL probe Z probing
{% set knobprobe_z = printer.knobprobe.last_z_result %} ; KnobProbe Z probing
{% set ref_delta_z = printer.probe.last_z_result - printer.knobprobe.last_z_result %} ; delta z for ref. tool
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="....cur_delta_z = probe.last_z_result - knobprobe.last_z_result"
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="....probe.last_z_result = "{probe_z}" , knobprobe.last_z_result = "{knobprobe_z}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".... -> SAVE_VARIABLE VARIABLE=ref_delta_z VALUE="{ref_delta_z}
SAVE_VARIABLE VARIABLE=ref_delta_z VALUE={ref_delta_z} ; save ref delta Z
[gcode_macro _SAVE_CUR_DELTA_Z]
description: Save current nozzle delta Z
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".._SAVE_CUR_DELTA_Z"
{% set probe_z = printer.probe.last_z_result %} ; ABL Z probing
{% set knobprobe_z = printer.knobprobe.last_z_result %} ; knobprobe Z probing
{% set cur_delta_z = probe_z - knobprobe_z %} ; delta z for current tool
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".... -> SAVE_VARIABLE VARIABLE=cur_delta_z VALUE="{cur_delta_z}
SAVE_VARIABLE VARIABLE=cur_delta_z VALUE={cur_delta_z} ; save current probing offsets
[gcode_macro _CALC_GCODE_OFFSET]
description: Calculate and save gcode offset
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".._CALC_GCODE_OFFSET"
{% set cur_delta_z = printer.save_variables.variables.cur_delta_z %}
{% set gcode_offset = ref_delta_z - cur_delta_z %} ; gcode offset = difference
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="....gcode_offset = ref_delta_z - cur_delta_z : "
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG="....ref_delta_z = "{ref_delta_z}" , cur_delta_z = "{cur_delta_z}
RESPOND TYPE={printer.save_variables.variables.verbose_type} MSG=".... -> SAVE_VARIABLE VARIABLE=gcode_offset VALUE="{gcode_offset}
SAVE_VARIABLE VARIABLE=gcode_offset VALUE={gcode_offset} ; save gcode offset
klippy.zip (49.0 KB)
[EDIT] could the manual probing require also using SET_DOCKABLE_PROBE AUTO_ATTACH_DETACH=0 ??? Just thinking of it.
Will see tomorrow…
