Rpi zero w usb connection
Printer Model: Ender 3 V3
MCU / Printerboard: stock
…Trying to use a zero w as replacement for a pi 3B+. Used kiauh to install klipper, moonraker and mainsail. Everything seems to work with old klipper.bin and printer.cfg until time to connect. Kiauh indicates mcu is on /dev/ttyAMA0. Putting that into printer.cfg causes klipper to simply spin. klippy.log last few lines indicate it is waiting for a connection
"mcu ‘mcu’: Starting serial connect
webhooks client 3038670272: New connection
webhooks client 3038670272: Client info {‘program’: ‘Moonraker’, ‘version’: ‘v0.8.0-318-g9813011’}
“jroe@picam:~ $ ls -l /dev/serial*
lrwxrwxrwx 1 root root 7 Mar 1 10:17 /dev/serial1 → ttyAMA0”
It appears zero w doesn’t implement usb hotplug the same as 3 B+. Does anyone have a fix, maybe in the zero w?
klippy.log (12.3 KB)
Fixed my own problem! Turns out I could disable OTG mode in zero w, sorry to waste your time but maybe this might help some other misguided soul.
Maybe you could explain what you did? I’m curious to understand your solution.
sudo nano /boot/config.txt
add to bottom
dtoverlay=dwc2,dr_mode=host
save and reboot.
should fix it.
