Scara and Custom Kinematics C helper design
Printer Model: generic
MCU / Printerboard: mostly rp2040
Host / SBC: RPI5 8GB
klippy.log:
klippy.log (203.1 KB)
As a newbie here, i am starting with custom kinematics c helper.
my final goal is scara kinematics, though parallelogram 3-DOF might found it adoptable.
this is what i am working on now, more or less:
// SCARA kinematics stepper pulse time generation
// Copyright (C) 2025 R.Kaeter kaeter@gmail.com
// This file may be distributed under the terms of the GNU GPLv3 license.
#include <math.h> // sqrt, atan2, acos
#include <stddef.h> // offsetof
#include <stdlib.h> // malloc, free
#include <string.h> // memset
#include “compiler.h” // __visible
#include “itersolve.h” // struct stepper_kinematics
#include “trapq.h” // move_get_coord
struct scara_stepper {
    struct stepper_kinematics sk;
    double arm_a, arm_b;
// Inverse kinematics function for the first arm’s stepper (Angle 1)
static double
scara_stepper_calc_angle1(struct stepper_kinematics *sk, struct move m, double move_time)
    struct scara_stepper ss = container_of(sk, struct scara_stepper, sk);
    struct coord c = move_get_coord(m, move_time);
    double x = c.x;
    double y = c.y;
    double r2 = xx + yy;
    double r = sqrt(r2);
    double alpha = atan2(y, x);
    double beta = acos((ss->arm_a * ss->arm_a + r2 - ss->arm_b * ss->arm_b) / (2 * ss->arm_a * r));
    double theta1 = alpha + beta;
    return theta1;
// Inverse kinematics function for the second arm’s stepper (Angle 2)
static double
scara_stepper_calc_angle2(struct stepper_kinematics *sk, struct move m, double move_time)
    double x = c.x;
    double y = c.y;
    double theta2 = acos((r2 - ss->arm_a * ss->arm_a - ss->arm_b * ss->arm_b) / (2 * ss->arm_a * ss->arm_b));
    return theta2;
struct stepper_kinematics * __visible
scara_stepper_alloc(char angle, double arm_a, double arm_b)
    struct scara_stepper *ss = malloc(sizeof(*ss));
    if (!ss)
        return NULL;
    memset(ss, 0, sizeof(*ss));
    ss->arm_a = arm_a;
    ss->arm_b = arm_b;
    switch(angle) {
        case ‘a’:
            ss->sk.calc_position_cb = scara_stepper_calc_angle1;
            break;
        case ‘b’:
            ss->sk.calc_position_cb = scara_stepper_calc_angle2;
            break;
    ss->sk.active_flags = AF_X | AF_Y;
    return &ss->sk;
Please kindly suggest or comment, as i like to fine tune the c helper before move on to the python side. My assumption are the printer kinematics mechanism and printer config can be as general yet generic as possible :slight_smile: . Thx
Regards,
Kaeter
Hello @kaeter !
Please:
Also, when posting code, please use the Preformatted Text feature of the forum editor to prevent error due to the final formatting.
Format
Hi, thanks for the advice. Noted. :slight_smile:
