Hey Myke, so good news looks like setting an appropriate homing speed (up to double the rotation distance per second) on a TMC2209 with default sense resistor (110 mOhm) did the trick thankfully. I am trying this on a lead screw actuator with a pitch of 2 mm and rms current of 0.6 I had in my inventory while waiting for new smaller actuators to come in.
Now I was wondering if it is possible to home even faster while ensuring reliability in detecting the stall and edge spike in voltage as it does take quite some time to home so was hoping for user experience sake in the mechanism I am prototyping it would be more efficient.
What I have done so far is implement a macro in the Klipper config file that temporarily sets the acceleration to very low values (tried 1-10 mm/s^2) to try and compensate for higher velocities (been trying 10-15 mm/s). However this has not allowed me to replicate the clean stall detection I managed to achieve with the lower velocities unfortunately.
The klipper config for this stepper, the driver and macro is as follows:
Motor1
stepper_x
step_pin: PE6
dir_pin: !PE5
enable_pin: !PC14
rotation_distance: 2
endstop_pin: tmc2209_stepper_x:virtual_endstop
position_endstop: 0
position_max: 135
homing_speed: 15
homing_retract_dist: 0
tmc2209 stepper_x
uart_pin: PC13
diag_pin: ^PF4
run_current: 0.3
hold_current: 0.1
stealthchop_threshold: 999999
interpolate: false
sense_resistor: 0.110
driver_SGTHRS: 75 # tune this (0..255, where 255 is most sensitive)
gcode_macro HOME_X_SMOOTH_FAST
#Fast homing speed with low accel during homing, then restore limits
{% set mv = printer.toolhead.max_velocity %}
{% set ma = printer.toolhead.max_accel %}
SET_VELOCITY_LIMIT ACCEL=2
G28 X
Restore normal limits
SET_VELOCITY_LIMIT VELOCITY={mv} ACCEL={ma}
I even tried doing an approach that involved a non-zero retracting distance and second homing speed. The approach i was trying is essentially:
fast first touch + slow second touch”
First pass: faster speed, low accel → gets to the stop quickly without nasty spikes.
Retract a small distance.
Second pass: slower speed, low accel → gives a clean, repeatable trigger point.
However, unfortunately the same outcome as approach 1. Attached are the logs I would see which just showcases basic endstop not triggered message. Note that steppers y, z and z1 not initailising is just because I have no motors or drivers currently plugged in for those motors but has not semed to affect it as I got successful sensorless homing even with these messages.
mcu ‘mcu’: Starting serial connect
webhooks client 140736365581648: New connection
webhooks client 140736365581648: Client info {‘program’: ‘Moonraker’, ‘version’: ‘v0.9.3-130-g5b92e52’}
Loaded MCU ‘mcu’ 133 commands (v0.13.0-452-g8dd798eb / gcc: (15:14.2.rel1-1) 14.2.1 20241119 binutils: (2.44-3+23+b2) 2.44)
MCU ‘mcu’ config: ADC_MAX=4095 BUS_PINS_i2c1_PB6_PB7=PB6,PB7 BUS_PINS_i2c1_PB8_PB9=PB8,PB9 BUS_PINS_i2c2_PB10_PB11=PB10,PB11 BUS_PINS_i2c3_PA8_PC9=PA8,PC9 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi2b=PI2,PI3,PI1 BUS_PINS_spi3a=PC11,PC12,PC10 BUS_PINS_spi4=PE13,PE14,PE12 BUS_PINS_spi5=PF8,PF9,PF7 BUS_PINS_spi5a=PH7,PF11,PH6 BUS_PINS_spi6=PG12,PG14,PG13 CLOCK_FREQ=520000000 MCU=stm32h723xx PWM_MAX=257 RESERVE_PINS_USB=PA11,PA12 RESERVE_PINS_crystal=PH0,PH1 STATS_SUMSQ_BASE=256 STEPPER_STEP_BOTH_EDGE=1
Configured MCU ‘mcu’ (1024 moves)
TMC stepper_y failed to init: Unable to write tmc spi ‘stepper_y’ register GLOBALSCALER
TMC stepper_z failed to init: Unable to write tmc spi ‘stepper_z’ register GLOBALSCALER
TMC stepper_z1 failed to init: Unable to write tmc spi ‘stepper_z1’ register GLOBALSCALER
webhooks: registering remote method ‘shutdown_machine’ for connection id: 140736365581648
webhooks: registering remote method ‘reboot_machine’ for connection id: 140736365581648
webhooks: registering remote method ‘pause_job_queue’ for connection id: 140736365581648
webhooks: registering remote method ‘start_job_queue’ for connection id: 140736365581648
Stats 4747.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1829 bytes_read=5795 bytes_retransmit=9 bytes_invalid=0 send_seq=165 receive_seq=165 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=22 upcoming_bytes=0 freq=520029811 print_time=3404.226 buffer_time=0.228 print_stall=0 sysload=0.38 cputime=0.305 memavail=1477808
Stats 4748.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1862 bytes_read=5816 bytes_retransmit=9 bytes_invalid=0 send_seq=167 receive_seq=167 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520010657 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.38 cputime=0.306 memavail=1478368
Stats 4749.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000003 mcu_task_stddev=0.000007 bytes_write=1868 bytes_read=5847 bytes_retransmit=9 bytes_invalid=0 send_seq=168 receive_seq=168 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520008203 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.307 memavail=1479888
Stats 4750.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000003 mcu_task_stddev=0.000007 bytes_write=1874 bytes_read=5863 bytes_retransmit=9 bytes_invalid=0 send_seq=169 receive_seq=169 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520006236 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.308 memavail=1481712
Stats 4751.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000003 mcu_task_stddev=0.000007 bytes_write=1880 bytes_read=5879 bytes_retransmit=9 bytes_invalid=0 send_seq=170 receive_seq=170 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520004413 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.310 memavail=1483072
Stats 4752.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000003 mcu_task_stddev=0.000007 bytes_write=1886 bytes_read=5895 bytes_retransmit=9 bytes_invalid=0 send_seq=171 receive_seq=171 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520003932 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.312 memavail=1483392
Stats 4753.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000003 mcu_task_stddev=0.000007 bytes_write=1892 bytes_read=5911 bytes_retransmit=9 bytes_invalid=0 send_seq=172 receive_seq=172 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520002772 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.313 memavail=1483536
Stats 4754.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=1898 bytes_read=5940 bytes_retransmit=9 bytes_invalid=0 send_seq=173 receive_seq=173 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520001345 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.32 cputime=0.315 memavail=1480624
Stats 4755.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=1904 bytes_read=5956 bytes_retransmit=9 bytes_invalid=0 send_seq=174 receive_seq=174 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520001407 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.32 cputime=0.316 memavail=1480784
Stats 4756.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=1910 bytes_read=5972 bytes_retransmit=9 bytes_invalid=0 send_seq=175 receive_seq=175 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=520000990 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.32 cputime=0.318 memavail=1481680
Stats 4757.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=1916 bytes_read=5988 bytes_retransmit=9 bytes_invalid=0 send_seq=176 receive_seq=176 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519999891 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.32 cputime=0.319 memavail=1483328
Stats 4758.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=1922 bytes_read=6004 bytes_retransmit=9 bytes_invalid=0 send_seq=177 receive_seq=177 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519999087 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.32 cputime=0.321 memavail=1483808
Stats 4759.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1928 bytes_read=6033 bytes_retransmit=9 bytes_invalid=0 send_seq=178 receive_seq=178 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519999256 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.30 cputime=0.322 memavail=1484736
Stats 4760.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1934 bytes_read=6049 bytes_retransmit=9 bytes_invalid=0 send_seq=179 receive_seq=179 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998775 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.30 cputime=0.324 memavail=1483760
Stats 4761.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1940 bytes_read=6065 bytes_retransmit=9 bytes_invalid=0 send_seq=180 receive_seq=180 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998712 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.30 cputime=0.326 memavail=1484016
Stats 4762.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1946 bytes_read=6081 bytes_retransmit=9 bytes_invalid=0 send_seq=181 receive_seq=181 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998882 print_time=3404.226 buffer_time=0.000 print_stall=0 sysload=0.30 cputime=0.328 memavail=1483984
Stats 4763.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000000 mcu_task_stddev=0.000000 bytes_write=1985 bytes_read=6132 bytes_retransmit=9 bytes_invalid=0 send_seq=184 receive_seq=184 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998462 print_time=3419.453 buffer_time=0.000 print_stall=0 sysload=0.30 cputime=0.331 memavail=1484624
toolhead: max_velocity: 10.000000
max_accel: 2.000000
minimum_cruise_ratio: 0.000000
square_corner_velocity: 5.000000
Stats 4764.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=2734 bytes_read=6746 bytes_retransmit=9 bytes_invalid=0 send_seq=219 receive_seq=219 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998277 print_time=3420.954 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.344 memavail=1478768
toolhead: max_velocity: 1000.000000
max_accel: 1000.000000
Stats 4765.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3065 bytes_read=7109 bytes_retransmit=9 bytes_invalid=0 send_seq=240 receive_seq=240 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998158 print_time=3421.519 buffer_time=0.000 print_stall=0 sysload=0.35 cputime=0.352 memavail=1477264
toolhead: max_velocity: 15.000000
max_accel: 40.000000
Stats 4766.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3374 bytes_read=7191 bytes_retransmit=9 bytes_invalid=0 send_seq=247 receive_seq=247 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998118 print_time=3428.988 buffer_time=5.978 print_stall=0 sysload=0.35 cputime=0.357 memavail=1477024
Stats 4767.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3445 bytes_read=7258 bytes_retransmit=9 bytes_invalid=0 send_seq=251 receive_seq=251 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998126 print_time=3428.988 buffer_time=4.977 print_stall=0 sysload=0.35 cputime=0.361 memavail=1478576
Stats 4768.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3516 bytes_read=7325 bytes_retransmit=9 bytes_invalid=0 send_seq=255 receive_seq=255 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997933 print_time=3428.988 buffer_time=3.977 print_stall=0 sysload=0.35 cputime=0.365 memavail=1490592
Stats 4769.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3587 bytes_read=7406 bytes_retransmit=9 bytes_invalid=0 send_seq=259 receive_seq=259 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998123 print_time=3428.988 buffer_time=2.977 print_stall=0 sysload=0.41 cputime=0.370 memavail=1491664
Stats 4770.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3658 bytes_read=7473 bytes_retransmit=9 bytes_invalid=0 send_seq=263 receive_seq=263 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998266 print_time=3428.988 buffer_time=1.976 print_stall=0 sysload=0.41 cputime=0.373 memavail=1493728
Stats 4771.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3729 bytes_read=7540 bytes_retransmit=9 bytes_invalid=0 send_seq=267 receive_seq=267 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998345 print_time=3428.988 buffer_time=0.975 print_stall=0 sysload=0.41 cputime=0.377 memavail=1493088
Stats 4772.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=3996 bytes_read=7622 bytes_retransmit=9 bytes_invalid=0 send_seq=274 receive_seq=274 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998250 print_time=3428.988 buffer_time=0.000 print_stall=0 sysload=0.41 cputime=0.381 memavail=1493568
max_accel: 2.000000
Stats 4773.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=4200 bytes_read=7828 bytes_retransmit=9 bytes_invalid=0 send_seq=285 receive_seq=285 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998354 print_time=3430.212 buffer_time=0.198 print_stall=0 sysload=0.41 cputime=0.388 memavail=1494368
Stats 4774.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=4757 bytes_read=8153 bytes_retransmit=9 bytes_invalid=0 send_seq=308 receive_seq=307 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519998155 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.395 memavail=1490304
Stats 4775.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=5153 bytes_read=8511 bytes_retransmit=9 bytes_invalid=0 send_seq=331 receive_seq=330 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997956 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.401 memavail=1490416
Stats 4776.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=5545 bytes_read=8855 bytes_retransmit=9 bytes_invalid=0 send_seq=354 receive_seq=353 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997817 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.409 memavail=1491824
Stats 4777.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=5958 bytes_read=9199 bytes_retransmit=9 bytes_invalid=0 send_seq=377 receive_seq=376 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997718 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.417 memavail=1492720
Stats 4778.6: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=6493 bytes_read=9562 bytes_retransmit=9 bytes_invalid=0 send_seq=400 receive_seq=400 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997817 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.423 memavail=1493168
Stats 4779.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=6880 bytes_read=9918 bytes_retransmit=9 bytes_invalid=0 send_seq=423 receive_seq=423 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997663 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.430 memavail=1496048
Stats 4780.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=7264 bytes_read=10256 bytes_retransmit=9 bytes_invalid=0 send_seq=446 receive_seq=446 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997708 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.438 memavail=1496896
Stats 4781.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=7656 bytes_read=10614 bytes_retransmit=9 bytes_invalid=0 send_seq=469 receive_seq=469 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997817 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.446 memavail=1513984
Stats 4782.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=8041 bytes_read=10958 bytes_retransmit=9 bytes_invalid=0 send_seq=492 receive_seq=492 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997725 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.453 memavail=1517888
Stats 4783.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=8426 bytes_read=11302 bytes_retransmit=9 bytes_invalid=0 send_seq=515 receive_seq=515 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997737 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.459 memavail=1519856
Stats 4784.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=8818 bytes_read=11674 bytes_retransmit=9 bytes_invalid=0 send_seq=538 receive_seq=538 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997692 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.465 memavail=1524272
Stats 4785.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=9203 bytes_read=12018 bytes_retransmit=9 bytes_invalid=0 send_seq=561 receive_seq=561 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997742 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.471 memavail=1531264
Stats 4786.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=9588 bytes_read=12362 bytes_retransmit=9 bytes_invalid=0 send_seq=584 receive_seq=584 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997657 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.478 memavail=1533312
Stats 4787.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=9977 bytes_read=12720 bytes_retransmit=9 bytes_invalid=0 send_seq=607 receive_seq=607 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997558 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.485 memavail=1534960
Stats 4788.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=10358 bytes_read=13055 bytes_retransmit=9 bytes_invalid=0 send_seq=630 receive_seq=630 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997500 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.493 memavail=1535312
Stats 4789.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=10743 bytes_read=13413 bytes_retransmit=9 bytes_invalid=0 send_seq=653 receive_seq=653 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997421 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.502 memavail=1535840
Stats 4790.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=11135 bytes_read=13771 bytes_retransmit=9 bytes_invalid=0 send_seq=676 receive_seq=676 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997464 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.509 memavail=1539408
Stats 4791.6: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=11520 bytes_read=14115 bytes_retransmit=9 bytes_invalid=0 send_seq=699 receive_seq=699 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997523 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.520 memavail=1539616
Stats 4792.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=11905 bytes_read=14459 bytes_retransmit=9 bytes_invalid=0 send_seq=722 receive_seq=722 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997478 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.528 memavail=1541952
Stats 4793.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=12297 bytes_read=14817 bytes_retransmit=9 bytes_invalid=0 send_seq=745 receive_seq=745 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997570 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.37 cputime=0.537 memavail=1543392
Stats 4794.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=12794 bytes_read=15175 bytes_retransmit=9 bytes_invalid=0 send_seq=768 receive_seq=768 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997566 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.544 memavail=1534384
Stats 4795.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=13225 bytes_read=15519 bytes_retransmit=9 bytes_invalid=0 send_seq=791 receive_seq=791 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997560 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.553 memavail=1534848
Stats 4796.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=13641 bytes_read=15870 bytes_retransmit=9 bytes_invalid=0 send_seq=814 receive_seq=814 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997580 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.560 memavail=1535600
Stats 4797.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=14026 bytes_read=16214 bytes_retransmit=9 bytes_invalid=0 send_seq=837 receive_seq=837 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997602 print_time=3430.212 buffer_time=0.000 print_stall=0 sysload=0.34 cputime=0.567 memavail=1537104
Stats 4798.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=14583 bytes_read=16768 bytes_retransmit=9 bytes_invalid=0 send_seq=871 receive_seq=871 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997614 print_time=3455.223 buffer_time=0.197 print_stall=0 sysload=0.34 cputime=0.576 memavail=1539536
Stats 4799.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=14656 bytes_read=16896 bytes_retransmit=9 bytes_invalid=0 send_seq=877 receive_seq=877 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997623 print_time=3455.709 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.580 memavail=1537856
Stats 4800.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=14690 bytes_read=16958 bytes_retransmit=9 bytes_invalid=0 send_seq=880 receive_seq=880 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997593 print_time=3455.709 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.582 memavail=1539168
max_accel: 2.000000
Stats 4801.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=15338 bytes_read=17427 bytes_retransmit=9 bytes_invalid=0 send_seq=909 receive_seq=909 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997586 print_time=3458.259 buffer_time=0.231 print_stall=0 sysload=0.31 cputime=0.592 memavail=1543744
Stats 4802.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=15419 bytes_read=17556 bytes_retransmit=9 bytes_invalid=0 send_seq=915 receive_seq=915 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997533 print_time=3458.259 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.595 memavail=1546912
Stats 4803.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=15453 bytes_read=17618 bytes_retransmit=9 bytes_invalid=0 send_seq=918 receive_seq=918 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997602 print_time=3458.259 buffer_time=0.000 print_stall=0 sysload=0.31 cputime=0.598 memavail=1547968
Stats 4804.7: gcodein=0 mcu: mcu_awake=0.000 mcu_task_avg=0.000001 mcu_task_stddev=0.000001 bytes_write=15487 bytes_read=17693 bytes_retransmit=9 bytes_invalid=0 send_seq=921 receive_seq=921 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=519997664 print_time=3458.259 buffer_time=0.000 print_stall=0 sysload=0.29 cputime=0.600 memavail=1543584
Any ideas to workaround homing with faster velocities?
