Sensorless homing X returns Unhandled exception during run
I often have those layer 8 issues as well.
Nice the read that it is now working! :slight_smile:
Great to hear that you got it working - congratulations!
Have to be honest,thought your idea was a waste of time, cause its the bed and unrelated to the z/x axis.
But from my work with computers and cars i learned to just do it, to eliminate everything. And of course it led me to, “huh, why are you z_hopping when homing y” and the solution. and another example of, just do it ignore that you think its a waste or a dumb idea.
Maaaaybe a thing it’s would be nice to add to the documentation to. that any Z-hop is a bad idea. if Z is in the loop.
When working with 3D printers (all electronic devices, actually), I’ve found that it’s critical to be as consistent as possible across different functions for two reasons:
  1. It makes scanning for typos and errors much easier.
  2. It ensures the multiple hardware devices (both electronic and mechanical) are as similar as possible so that if one device is having a problem then finding the differences that are the reason for the problem becomes easier to find.
In my experience, suggesting that source/configuration/text/data files are made as consistent as possible results in finding the error 30% to 40% of the time. This was one of those cases.
Still, I think Klipper’s reaction is quite strange and an unhandled exception should not happen- @Scarte, can you provide the needed information how to reproduce this?
Tell me what you need and i will give it to you.
short of it is.
coreXZ, sensorless X, everything correct with hw, but Z_HOP set to 10mm in safe home in printer.cfg
