Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
Thanks for your response. I understand that my position_min setting is what’s causing the issue but do you know where I can modify the CUSTOM_POS_Y variable to 15?
