SKR 3 ez and BTT pad 7 setup help
I just received my new skr 3 ez and pad 7. I made the firmware for the board through the klipper software on the pad 7. i flashed the firmware to the skr3 board. after that i got the generic cfg file fromt he klipper website and install both on the pad and board. i’m getting mcu error unable to connect. i’ve search the web and tried various things but still seem to be hitting a wall. I really havent found any video or tutourial on set up the two together. it one or the other. Any help would be appriciated. TIA
Tronxy XS5A Pro
SKR3 Ez
BTT Pad 7
klippy (2).log (91.6 KB)
Printer Model:
MCU / Printerboard:
I figured out what my problem. I kept getting mcu not connected l. I did everything on the net trying to identify what my usb id was. Nothing worked. Kept getting no such directory or anything. Everyform said try this then that. Nothing. Sitting here going through the skr3 manual i found a but that enables the usd from the can bus. One click and problem fix.
