SKR-3 v3 (STM32H723) Option 'serial' in section 'mcu' must be specified
Printer Model: custom coreXY
MCU / Printerboard: SKR-3 v3(STM32H723)
klippy (2).log (1.7 KB)
Hi, I have an issue of motherboard not detect to klipper so that I can’t mentioed [mcu] serial without port detections.
I try all the thing which is mentioned on klipper installation document aswell as community post for that but I am not getting result.
Need help to achieve the goal.
Hardware : SKR-3 v3, Rpi-3, waveshare 5inch touch display
Hello @Jeet09 !
There is nothing (ZERO) in the config file.
klippy.log (29.1 KB)
I directly copy .cfg file from github and flash it though SD card using make . It successfully flash because firmware.bin file rename to firmware.cur file.
I further check for port using ls /dev/serial/by-id/* this command but it;s give error like ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory. without that I can not connect to MCU.
That does not mean that is works properly on the MCU.
That one of the first steps. Have you tried different USB cables?
Where are you running Klipper on?
But I read somewhere that bin file goes to cur file firmware was flashed.
Yes, I change cable for that still got error.
Mailsail OS
Typically yes, but it also will potentially flash a firmware compiled with wrong settings. Getting the settings and MCU type correct is of extreme importance.
Also refer to the discussion here SKR3 V3 Problem 'ls /dev/serial/by-id/`
Thanks for sharing. I go through it and I check low level config for motherboard in that I didn’t mention crystal value that’s why port not detect. After I set the value and flashed firmware it give output of port.
Thanks for Helping.
