START_PRINT issues! jinja2.exceptions
Printer Model: x5sa
MCU / Printerboard: skr 2
Host / SBC Android 9.0 tv box
klippy (3).log (2.9 MB)
Unable to start printing my printer immediately starts temp to attempt move then get this error "Error evaluating ‘gcode_macro START_PRINT:gcode’: jinja2.exceptions.UndefinedError: ‘dict object’ has no attribute ‘BED’ "
See Using START_PRINT and END_PRINT Macros how to correctly handle such macros.
Your issue probably is that you do not call it correctly from your slicer.
This is my Cura Start G-code
START_PRINT BED_TEMP={material_print_temperature_layer_0} EXTRUDER_TEMP={material_bed_temperature_layer_0}
now the previous error is gone and I am now receiving a “Error on ‘M190 S’: unable to parse”
Case sensitive: BED_TEMP is not the same as bed_temp
What you said worked, and now I got this error “Requested temperature (285.0) out of range (0.0:130.0)”.
Honestly I believe I will have to just start from scratch due to having so many conflicts with each correction. So much for trying to get this to work sooner.
I will be back after I clean up with file just not to waste anybody’s time.
In the help article there was a copy / paste mishap that switched bed and nozzle temps for the Cura example. I just fixed this.
Thanks @EddyMI3D for pointing it out!
I ended up just using the beginners guide on klippers website, thank you!
