START_PRINT Gcode error
Printer Model: TwoTrees SP5 V3
MCU / Printerboard: MKS Robin Nano V3
Host / SBC BTT Pad7
klippy.log (253.5 KB)
I’m trying to get a handle on macros but I can’t get past the START_PRINT macro throwing an error “Can’t parse command M140 S”. It’s a “borrowed” macro with minor changes, temps and coordinates, by me. As always help is appreciated. Here’s the macro:
[gcode_macro START_PRINT]
    {% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(140)|float %}
        # Start bed heating
    M140 S{BED_TEMP}
    # Use absolute coordinates
    G90
    # Reset the G-Code Z offset (adjust Z offset if needed)
    SET_GCODE_OFFSET Z=0
    SFS_ENABLE ;ENABLE FILAMENT SENSOR
    [gcode_macro CG28] # Home the printer if not already homed
    {% if "xyz" not in printer.toolhead.homed_axes %}
        G28
    M190 S{BED_TEMP} # Wait for bed to reach temperature
    # Set and wait for nozzle to reach temperature
    M109 S{EXTRUDER_TEMP}
    #reset extruder position
    G92 E0
    # Leave any oozing behind (hopefully) 4/23/25
    G1 Z5 F350 # Move the nozzle near the bed
    ;G1 E-1 F300
    G1 X2 Y0 F2000 #Move nozzle to antioozing :) line start
    G1 Z0.15 F300    # Move the nozzle very close to the bed
    G1 Y10 F2200
    ;G1 Y5 E0 F1000
    ;G1 X5 E0 F3000
    G1 Z0.28 F450
    G1 X2 Y30 F3000 #Move to prime line start
    G92 E0
    G1 Y210 E10 F1500 # prime the nozzle #1/25/25
    G1 X3 F5000
    G92 E0
    G1 Y30 E10 F1200 # prime the nozzle #1/25/25
    G92 E0
        # Start bed heating
    M140 S{BED_TEMP}
    G90
        G28
    G92 E0
    ;G1 E-1 F300
    G1 Y10 F2200
    ;G1 Y5 E0 F1000
    ;G1 X5 E0 F3000
    G1 Z0.28 F450
    G92 E0
    G1 X3 F5000
    G92 E0
    G92 E0
The spaces in line 14 before [gcode_macro ... should be deleted.
The Start_print macro in the klippy.log looks different that the one you posted.
gcode =
	G28
	M190 S{BED_TEMP}
	G92 E0
	G1 Z5 F350
	G1 X2 Y0 F2000
	G1 Z0.15 F300
	G1 Y10 F2200
	G1 Z0.28 F450
	G1 X2 Y30 F3000
	G92 E0
	G1 Y210 E10 F1500
	G1 X3 F5000
	G92 E0
	G1 Y30 E10 F1200
	G92 E0
I removed the spaces and that solved that issue. I’m still trying to figure out these macros. Now I’m getting an error “Can’t reset SD card from SD card” . So I’ll delve into that today. Start commenting things out until I get an Ah-Ha moment.
As to why the Klippy log shows a different start code the the one in Macros.cfg that’s above my paygrade. I even saved everything, restarted Klipper and downloaded the log and it looks the same as the one you posted. This is the first time I really looked at that log, it’s interesting all that it shows. Now I know why it’s uploaded when posting here.
Thanks again.
