Problem gcode_macro print_start
Printer Model: Artillery X1
MCU / Printerboard:
good afternoon, I am trying to start klipper on my artillery x1 using a BIGTREETECH PAD. I have the following problem that I cannot solve.
Option ‘{ set bed_temp’ is not valid in section ‘gcode_macro print_start’
[gcode_macro PRINT_START]
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(200)|float %}
Can you help me please?
You need to post your log as instructed.
Some sneppets from my MMU GCode as example …
[gcode_macro USE_MMU]
	SET_GCODE_VARIABLE MACRO=VAR_MMU2S VARIABLE=mmu_enabled VALUE={params.VALUE}
# park the idler, stop the delayed stop of the heater
[gcode_macro MMU_UNLOCK]
   {% if printer["gcode_macro VAR_MMU2S"].is_paused|int != 0 %}
   M118 Unlock MMU
   SET_GCODE_VARIABLE MACRO=VAR_MMU2S VARIABLE=is_paused VALUE=0
   HOME_IDLER
   {% else %}
   M118 MMU not locked
Could you please put your code between code bracers? Without it is of no use at all.
Format
