Stealth changer fails to detect active tool
Printer Model: Voron 2.4
MCU / Printerboard: Leviathan 1.2 Other MCUs(Isik’s Tech Birds’ Nest, Orbitool 2)
Host / SBC: Raspberry Pi 4
klippy.log (303.5 KB)
config-20251121-190725.zip (14.1 KB)
I have been having issues getting getting my Stealth changer build working correctly. I am able to see almost everything that is connected. The only exception that I have is my tap sensors. I know that the sensors work with my current setup as the switch on the current tool worked before I installed klipper tool changer Now I am unable to zero my Z axis.
I have scoured my Configs and haven’t found anything that I can see wrong. I have attached the configs that I think are relevant to my problem just in case you need information that is not in the log file, that is a fresh log starting the printer and trying to home. I have also connected a second head to try and prevent the error of all or none of the sensors being triggered.
The current error messages I get when trying to home my machine are “Failed to detect active tool”, “Internal error on command:“INITIALIZE_TOOLCHANGER”“ , “and Internal error on command:“G28”“ These errors have persisted even if changed the polarity of either of my current connected switches of if I switch which tool is being used.
Any help would be greatly appreciated.
Hi @MetalDragon ,
I would ask this on the StealthChanger (Draftshift Design) discord.
