Unable to Home Z axis "no active tool probe"
Printer Model: Voron 2.4
MCU / Printerboard:BTT Manta M8P
Hello there,
i rencently finished my Voron 2.4 and got it working.
Next step is a toolchanger version as seen from creator “viesturz”,
tapchanger and his github.
I copied some of his code and also modified some, because with a pure copy i got some problems, i think becaus of modifications on his printer, that i dont have.
But the issue now is, i cant home Z axis anymore, endstops-check also not possible.
In my previous working Config i had a [probe] section with defined probe pin (optical sensor via EBB36 board) like this:
[probe]
pin: ^T0: PB9
etc…
but now it says “Option ‘pin’ is not valid in section ‘probe’”
there is now a section [toolprobe_T0] and [toolprobe_T1] (that i copied from viesturz config) but i guess i need to tell the system that probe is now within toolprobe_T0. But nowhere in any file i can identifiy anything like this to include in my .cfg
I hope u can understand the problem.
Thank u for reading this and greetings,
Niko
klippy (10).log (159.3 KB)
Hello @SpankySummers !
First, let’s get @Viesturz into the boat.
You maybe have to tell Klipper what the active tool/probe is.
https://www.klipper3d.org/G-Codes.html#activate_extruder
We do that on IDEX printers.
thanks for your reply, the toolprobe was already active, that wasnt the issue.
But your idea got me in the right direction and i got it solved.
The active toolhead is identified via the NOT triggered z-endstop and since i only got one (didnt think i need endstops on the other tools) the active tool could not be determined. (no sensor on second toolhead made it look like not triggered also)
i could make it work with shorting the pins on second toolhead, making it think it is triggered. another opto-tap is ordered.
Thank you EddyMI3D for the input, if not already clear i have no programming background and am just tinkering around with code i see.
Thats why i am very thankful of all the information out there from so many talented people that are also willing to share and help.
I will mark this post as solved, since the missing probe is the issue. But im also pretty sure this wasn’t my last question :wink:
Grettings, Niko
