Super Racer Lost MCU
Printer Model: FLSUN Super Racer
MCU / Printerboard: Robin Nano V3
klippy-1.log (606.2 KB)
I am getting constant MCU Lost Communication errors. Happens at all different times. I have tried to read through the log but it might as well be in Martian. I have been fighting this for a month now. I have changed all the cords, used different power supplies and nothing works. Running a speeder pad with the firmware from FLSUN and I created the firmware for the printer using Moba. Please help before I pull out what little hair I have left.
This can usually be fixed by using a new, quality USB cable: Got EOF when reading from device
I’ve used 10 different cords of varying lengths. All high speed/gold plated high quality cables and nothing changes.
What is your dmesg output on your Klipper host?
[    3.017652] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[    3.018235] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.018438] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.039411] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    3.039559] sunxi_mmc_get_hs400_cmd_dly,222
[    3.039568] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    3.039613] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    3.039757] sunxi_mmc_get_hs400_cmd_dly,222
[    3.039765] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    3.061213] mmc0: new HS400 MMC card at address 0001
[    3.063749] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[    3.064610] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[    3.069362] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[    3.074023] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[    3.077396]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    3.152158] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    3.161571] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    3.170984] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    3.180396] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    3.189808] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    3.190898] random: fast init done
[    3.203804] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.48 2020-9-15 16:01)
[    3.212822] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[    3.218280] sunxi-mmc sdc0: No vmmc regulator found
[    3.223778] sunxi-mmc sdc0: No vqmmc regulator found
[    3.229372] sunxi-mmc sdc0: No vdmmc regulator found
[    3.234966] sunxi-mmc sdc0: No vd33sw regulator found
[    3.240658] sunxi-mmc sdc0: No vd18sw regulator found
[    3.246349] sunxi-mmc sdc0: No vq33sw regulator found
[    3.252040] sunxi-mmc sdc0: No vq18sw regulator found
[    3.258804] sunxi-mmc sdc0: set host busy
[    3.263419] sunxi-mmc sdc0: Got CD GPIO
[    3.268670] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.278985] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[    3.286414] usb 1-1.1.2: new high-speed USB device number 4 using sunxi-ehci
[    3.302410] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.330380] sunxi-mmc sdc0: detmode:gpio polling
[    3.330406] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    3.348139] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.48 2020-9-15 16:01)
[    3.357078] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[    3.362529] sunxi-mmc sdc1: No vmmc regulator found
[    3.368027] sunxi-mmc sdc1: No vqmmc regulator found
[    3.373621] sunxi-mmc sdc1: No vdmmc regulator found
[    3.379214] sunxi-mmc sdc1: No vd33sw regulator found
[    3.384906] sunxi-mmc sdc1: No vd18sw regulator found
[    3.390598] sunxi-mmc sdc1: No vq33sw regulator found
[    3.396289] sunxi-mmc sdc1: No vq18sw regulator found
[    3.403035] sunxi-mmc sdc1: set host busy
[    3.407671] mmc:failed to get gpios
[    3.412831] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.423165] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    3.446364] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.474368] sunxi-mmc sdc1: detmode:manually by software
[    3.475228] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    3.481220] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    3.486384] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.494475] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.496430] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.498443] usb 1-1.1.2: reset high-speed USB device number 4 using sunxi-ehci
[    3.507176] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.517934] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.523820] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.531156] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    3.532244] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.532322] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    3.560269] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.589266] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    3.590080] sunxi_led_probe()1690 - start
[    3.590152] sunxi_get_str_of_property()1549 - failed to get the string of propname led_regulator!
[    3.610829] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    3.616833] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.630287] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.643298] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.650289] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.657265] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.664244] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    3.670141] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    3.670472] r8152 1-1.1.2:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[    3.689376] sunxi_led_probe()1782 - finish
[    3.690305] hidraw: raw HID events driver (C) Jiri Kosina
[    3.690998] usbcore: registered new interface driver usbhid
[    3.691001] usbhid: USB HID core driver
[    3.696053] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[    3.696061] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[    3.696068] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[    3.696076] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[    3.696084] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[    3.696786] sunxi-daudio daudio0: regulator missing or invalid
[    3.700579] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[    3.702566] [sunxi_card_init] card init finished.
[    3.703576] r8152 1-1.1.2:1.0 (unnamed net_device) (uninitialized): Random ether addr 3e:93:2e:d6:07:e8
[    3.705127] sunxi-codec-machine sndcodec: sun50iw10codec <-> 5096000.cpudai-controller mapping ok
[    3.707596] r8152 1-1.1.2:1.0 eth0: v1.08.9
[    3.710735] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
[    3.711398] u32 classifier
[    3.711401]     Actions configured
[    3.711615] Initializing XFRM netlink socket
[    3.718747] NET: Registered protocol family 10
[    3.725303] NET: Registered protocol family 17
[    3.726417] 8021q: 802.1Q VLAN Support v1.8
[    3.726568] Key type dns_resolver registered
[    3.776129] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[    3.776139] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
[    3.776599] cpu cpu1: opp_list_debug_create_link: Failed to create link
[    3.776606] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[    3.776661] cpu cpu2: opp_list_debug_create_link: Failed to create link
[    3.776667] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[    3.776720] cpu cpu3: opp_list_debug_create_link: Failed to create link
[    3.776726] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[    3.778572] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.7 (r)
[    3.778587] ======== dhd_wlan_init_plat_data ========
[    3.778596] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[    3.778599] dhd_wlan_init_gpio: oob_irq=15, oob_irq_flags=0x4084
[    3.778601] dhd_wifi_platform_load: Enter
[    3.778643] Power-up adapter 'DHD generic adapter'
[    3.778772] wifi_platform_set_power = 1
[    3.778775] ======== PULL WL_REG_ON(-1) HIGH! ========
[    3.779014] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[    3.779386] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[    3.971092] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.981403] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    4.006349] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.035959] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    4.043527] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    4.049484] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.063060] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.093440] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    4.099653] wifi_platform_bus_enumerate device present 1
[    4.102573] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.105550] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.110901] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    4.117434] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[    4.130156] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[    4.136105] ======== Card detection to detect SDIO card! ========
[    4.278784] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    4.289500] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    4.300492] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[    4.312845] mmc2: new high speed SDIO card at address 0001
[    4.336786] bcmsdh_register: register client driver
[    4.342470] bcmsdh_sdmmc_probe: Enter num=1
[    4.347302] bcmsdh_sdmmc_probe: Enter num=2
[    4.352007] bus num (host idx)=2, slot num (rca)=1
[    4.357378] found adapter info 'DHD generic adapter'
[    4.362999] sdioh_attach: set sd_f2_blocksize 256
[    4.368316] sdioh_attach: sd clock rate = 0
[    4.373438] dhdsdio_probe : no mutex held. set lock
[    4.379008] F1 signature read @0x18000000=0x1541a9a6
[    4.387277] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[    4.395397] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[    4.402764] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[    4.408910] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[    4.418182] dhd_attach(): thread:dhd_watchdog_thread:452 started
[    4.425104] dhd_attach(): thread:dhd_dpc:454 started
[    4.430809] dhd_attach(): thread:dhd_rxf:455 started
[    4.436417] dhd_deferred_work_init: work queue initialized
[    4.442618] dhd_bus_set_default_min_res_mask: Unhandled chip id
[    4.449452] sdioh_cis_read: func_cis_ptr[0]=0x1070
[    4.464297] Dongle Host Driver, version 1.579.77.41.7 (r)
[    4.472625] wl_ext_iapsta_attach_netdev: bssidx=0
[    4.477928] Register interface [wlan0]  MAC: b8:2d:28:1d:f7:54
[    4.486175] dhd_wl_ioctl: returning as busstate=0
[    4.491462] dhd_bus_devreset: == Power OFF ==
[    4.496562] bcmsdh_oob_intr_unregister: Enter
[    4.501450] bcmsdh_oob_intr_unregister: irq is not registered
[    4.507927] dhd_txglom_enable: enable 0
[    4.512229] dhd_conf_set_txglom_params: txglom_mode=multi-desc, use_rxchain=0
[    4.520233] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[    4.527645] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[    4.536234] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[    4.543938] dhd_bus_devreset:  WLAN OFF DONE
[    4.548759] wifi_platform_set_power = 0
[    4.553066] ======== PULL WL_REG_ON(-1) LOW! ========
[    4.559135] dhdsdio_probe : the lock is released.
[    4.564592] dhd_module_init: Exit err=0
[    4.570142] sunxi_ctp_startup: ctp_power_io is invalid.
[    4.576058] deviceless supply vcc-ctp not found, using dummy regulator
[    4.583667] get ctp_screen_max_x is fail, -22
[    4.694830] sunxi_i2c_drv_core_process()972 - [i2c6] Timeout when sending 9th SCL clk
[    4.703618] i2c_sunxi_drv_complete()1146 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x14)
[    4.713282] 0x07081600: 01011001 00000001 00002800 0001ffff
[    4.719635] 0x07081610: 00008040 00010004 00010010 00000000
[    4.726044] sunxi_i2c_drv_core_process()972 - [i2c6] Timeout when sending 9th SCL clk
[    4.734828] i2c_sunxi_drv_complete()1146 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x5d)
[    4.744487] 0x07081600: 11011001 00000001 0000bb00 00000001
[    4.750843] 0x07081610: 00008040 00010004 00010010 00000000
[    4.757401] sunxi_i2c_do_xfer()1923 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    4.767210] detect ret 2
[    4.770042] ======detect ok !=====
[    4.774375] GTP I2C Address:0x5d
[    4.778252] create_singlethread_workqueue goodix_resume.
[    4.784410] create_singlethread_workqueue goodix_wq.
[    4.902346] X_MAX = 800,Y_MAX = 480,TRIGGER = 0x01
[    4.927130] input: gt9xx_ts as /devices/virtual/input/input4
[    4.934887] IC Version: 911_1060
[    4.938620] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
[    4.948556] usb0-vbus: disabling
[    4.952207] ALSA device list:
[    4.955534]   #0: audiocodec
[    4.960185] EXT4-fs (mmcblk0p5): couldn't mount as ext3 due to feature incompatibilities
[    5.002786] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[    5.011963] VFS: Mounted root (ext4 filesystem) on device 179:5.
[    5.019606] devtmpfs: mounted
[    5.023234] Freeing unused kernel memory: 448K
[    5.146070] systemd[1]: System time before build time, advancing clock.
[    5.161913] systemd[1]: Failed to look up module alias 'autofs4': Function not implemented
[    5.177857] cgroup: cgroup2: unknown option "nsdelegate"
[    5.193668] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    5.219646] systemd[1]: Detected architecture arm64.
[    5.242867] systemd[1]: Set hostname to <speeder-pad>.
[    5.805419] random: systemd: uninitialized urandom read (16 bytes read)
[    5.813215] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.827088] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.838607] systemd[1]: Created slice system-getty.slice.
[    5.858567] random: systemd: uninitialized urandom read (16 bytes read)
[    5.866878] systemd[1]: Created slice system-modprobe.slice.
[    5.886463] random: systemd: uninitialized urandom read (16 bytes read)
[    5.894767] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.915200] systemd[1]: Created slice User and Session Slice.
[    5.934935] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.962682] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[    5.976008] systemd[1]: Reached target Remote File Systems.
[    5.998479] systemd[1]: Reached target Slices.
[    6.018516] systemd[1]: Reached target Swap.
[    6.038970] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.063976] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    6.074021] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.095420] systemd[1]: Listening on Journal Socket.
[    6.115440] systemd[1]: Listening on udev Control Socket.
[    6.134990] systemd[1]: Listening on udev Kernel Socket.
[    6.154969] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    6.164490] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
[    6.180266] systemd[1]: Mounting Kernel Debug File System...
[    6.202944] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    6.217872] systemd[1]: Starting Journal Service...
[    6.238967] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[    6.257604] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    6.278708] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    6.293893] systemd[1]: Starting Load Kernel Module efi_pstore...
[    6.320481] systemd[1]: Starting Load Kernel Module pstore_blk...
[    6.348480] systemd[1]: Starting Load Kernel Module pstore_zone...
[    6.376645] systemd[1]: Starting Load Kernel Module ramoops...
[    6.399278] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[    6.412834] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.430558] systemd[1]: Starting Load Kernel Modules...
[    6.456168] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.484137] systemd[1]: Starting udev Coldplug all Devices...
[    6.512863] systemd[1]: Started Journal Service.
[    6.736581] systemd-journald[1147]: Received client request to flush runtime journal.
[    7.926436]
               insmod_device_driver
[    8.270951] EXT4-fs (mmcblk0p5): resizing filesystem from 5536370 to 15204844 blocks
[    8.644212] systemd-journald[1147]: Failed to set ACL on /var/log/journal/2dc89acf896c426b888d4b89327fdda8/user-1000.journal, ignoring: Operation not supported
[    9.097215] sunxi-bt soc@03000000:bt@0: block state already is 1
[    9.281135] EXT4-fs (mmcblk0p5): resized filesystem to 15204844
[   10.939945] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.174315] random: crng init done
[   13.174333] random: 7 urandom warning(s) missed due to ratelimiting
[   16.206580] dhd_open: Enter ffffffc03a142480
[   16.206589] dhd_open : no mutex held. set lock
[   16.206599]
[   16.206604] wl_ext_iapsta_attach_netdev: bssidx=0
[   16.206609] wl_android_wifi_on in 1
[   16.206617] wl_android_wifi_on in 2: g_wifi_on=0
[   16.206622] wifi_platform_set_power = 1
[   16.206627] ======== PULL WL_REG_ON(-1) HIGH! ========
[   16.206923] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[   16.207364] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[   16.534414] sdio_reset_comm():
[   16.534442] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.536661] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.537884] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.581174] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   16.587228] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   16.593242] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   16.604224] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   16.617668] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[   16.961598] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.961797] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.961967] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   16.962073] sdioh_start: set sd_f2_blocksize 256
[   16.962518]
               dhd_bus_devreset: == WLAN ON ==
[   16.962613] F1 signature read @0x18000000=0x1541a9a6
[   16.965170] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[   16.966037] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[   16.966186] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   16.968668] dhd_conf_read_config: Ignore config file /lib/firmware/config.txt
[   16.968687] Final fw_path=/lib/firmware/fw_bcm43438a1.bin
[   16.968691] Final nv_path=/lib/firmware/nvram.txt
[   16.968695] Final clm_path=/lib/firmware/clm.blob
[   16.968699] Final conf_path=/lib/firmware/config.txt
[   16.970592] dhd_os_open_image: /lib/firmware/fw_bcm43438a1.bin (407537 bytes) open success
[   17.023916] dhd_os_open_image: /lib/firmware/nvram.txt (948 bytes) open success
[   17.024213] NVRAM version: AP6212A_NVRAM_V1.0.1_20160606
[   17.024745] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   17.097895] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   17.097992] bcmsdh_oob_intr_register: HW_OOB irq=15 flags=0x4
[   17.103611] Disable tdls_auto_op failed. -1
[   17.103620] dhd_preinit_ioctls: Set tcpack_sup_mode 0
[   17.103626] dhd_tcpack_suppress_set 352: already set to 0
[   17.104390] dhd_apply_default_clm: Ignore clm file /lib/firmware/clm.blob
[   17.107531] Firmware up: op_mode=0x0005, MAC=b8:2d:28:1d:f7:54
[   17.123641] dhd_preinit_ioctls Set scancache failed -23
[   17.137341]   Driver: 1.579.77.41.7 (r)
                 Firmware: wl0: Oct 18 2017 11:06:46 version 7.45.96.6 (2af1ebc@sh-git) (r) FWID 01-8d3f56c1 es7.c5.n4.a3
                 CLM: 7.11.15
[   17.137724] dhd_txglom_enable: enable 1
[   17.137730] dhd_conf_set_txglom_params: txglom_mode=multi-desc, use_rxchain=0
[   17.137736] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
[   17.137740] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[   17.137745] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[   17.137754] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[   17.139225] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[   17.141360] dhd_pno_init: Support Android Location Service
[   17.141374] dhd_preinit_ioctls: SensorHub diabled 0
[   17.142161] dhd_preinit_ioctls failed to set ShubHub disable
[   17.142979] dhd_ndo_get_version: failed, retcode = -23
[   17.143923] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[   17.143931] failed to get wnm_bsstrans_resp
[   17.144686] failed to set WNM capabilities
[   17.169592] dhd_conf_set_country: set country CN, revision 0
[   17.169595] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   17.172847] Country code: CN (CN/0)
[   17.175690] wl_android_wifi_on: Success
[   17.189399] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[   17.202719] dhd_open : the lock is released.
[   17.202729] dhd_open: Exit ret=0
[   17.378777] P2P interface registered
[   17.378792] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc039f4f880, wdev->net:           (null)
[   17.414907] WLC_E_IF: NO_IF set, event Ignored
[   17.417502] P2P interface started
[   17.834580] wl_run_escan: LEGACY_SCAN sync ID: 0, bssidx: 0
[   26.811817] wl_run_escan: LEGACY_SCAN sync ID: 1, bssidx: 0
[   37.578494] usb 1-1.4: new full-speed USB device number 5 using sunxi-ehci
[   37.709564] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[   67.663741] wl_run_escan: LEGACY_SCAN sync ID: 2, bssidx: 0
[  117.403816] wl_run_escan: LEGACY_SCAN sync ID: 3, bssidx: 0
[  118.540537] Connecting with f8:9b:6e:42:bb:14 ssid "NotYours1", len (9) channel=10
[  118.581940] wl_bss_connect_done succeeded with f8:9b:6e:42:bb:14
[  118.602124] wl_bss_connect_done succeeded with f8:9b:6e:42:bb:14 vndr_oui: 00-10-18
[  154.897219] systemd-journald[1147]: Failed to set ACL on /var/log/journal/2dc89acf896c426b888d4b89327fdda8/user-1000.journal, ignoring: Operation not supported
[  248.110825] wl_run_escan: LEGACY_SCAN sync ID: 4, bssidx: 0
[  278.347988] wl_run_escan: LEGACY_SCAN sync ID: 5, bssidx: 0
[  458.105068] wl_run_escan: LEGACY_SCAN sync ID: 6, bssidx: 0
[  471.018681] usb 1-1.4: USB disconnect, device number 5
[  549.833493] usb 1-1.4: new full-speed USB device number 6 using sunxi-ehci
[  549.971416] cdc_acm 1-1.4:1.0: ttyACM1: USB ACM device
[  583.915000] usb 1-1.4: USB disconnect, device number 6
[  604.616840] usb 1-1.4: new full-speed USB device number 7 using sunxi-ehci
[  604.744007] cdc_acm 1-1.4:1.0: ttyACM1: USB ACM device
[  620.398525] wl_run_escan: LEGACY_SCAN sync ID: 7, bssidx: 0
[  746.986688] usb 1-1.4: USB disconnect, device number 7
[  750.024529] usb 1-1.4: new full-speed USB device number 8 using sunxi-ehci
[  750.153974] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[  801.091845] wl_run_escan: LEGACY_SCAN sync ID: 8, bssidx: 0
[  981.086630] wl_run_escan: LEGACY_SCAN sync ID: 9, bssidx: 0
[ 1161.111925] wl_run_escan: LEGACY_SCAN sync ID: 10, bssidx: 0
[ 1187.818816] usb 1-1.4: USB disconnect, device number 8
[ 1191.115480] usb 1-1.4: new full-speed USB device number 9 using sunxi-ehci
[ 1191.235089] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 1341.138187] wl_run_escan: LEGACY_SCAN sync ID: 11, bssidx: 0
[ 1521.073017] wl_run_escan: LEGACY_SCAN sync ID: 12, bssidx: 0
[ 1701.069631] wl_run_escan: LEGACY_SCAN sync ID: 13, bssidx: 0
[ 1881.067619] wl_run_escan: LEGACY_SCAN sync ID: 14, bssidx: 0
[ 2061.062972] wl_run_escan: LEGACY_SCAN sync ID: 15, bssidx: 0
[ 2079.722609] usb 1-1-port4: disabled by hub (EMI?), re-enabling...
[ 2079.730141] usb 1-1.4: USB disconnect, device number 9
[ 2079.967622] usb 1-1.4: new full-speed USB device number 10 using sunxi-ehci
[ 2080.089228] cdc_acm 1-1.4:1.0: ttyACM1: USB ACM device
[ 2241.068966] wl_run_escan: LEGACY_SCAN sync ID: 16, bssidx: 0
[ 2421.052214] wl_run_escan: LEGACY_SCAN sync ID: 17, bssidx: 0
[ 2601.047890] wl_run_escan: LEGACY_SCAN sync ID: 18, bssidx: 0
[ 2781.040854] wl_run_escan: LEGACY_SCAN sync ID: 19, bssidx: 0
[ 2961.057389] wl_run_escan: LEGACY_SCAN sync ID: 20, bssidx: 0
[ 3141.032882] wl_run_escan: LEGACY_SCAN sync ID: 21, bssidx: 0
[ 3321.059741] wl_run_escan: LEGACY_SCAN sync ID: 22, bssidx: 0
[ 3501.025643] wl_run_escan: LEGACY_SCAN sync ID: 23, bssidx: 0
[ 3681.020420] wl_run_escan: LEGACY_SCAN sync ID: 24, bssidx: 0
[ 3861.018415] wl_run_escan: LEGACY_SCAN sync ID: 25, bssidx: 0
[ 4041.013821] wl_run_escan: LEGACY_SCAN sync ID: 26, bssidx: 0
[ 4221.033835] wl_run_escan: LEGACY_SCAN sync ID: 27, bssidx: 0
[ 4400.874155] usb 1-1-port4: disabled by hub (EMI?), re-enabling...
[ 4400.881404] usb 1-1.4: USB disconnect, device number 10
[ 4401.002313] wl_run_escan: LEGACY_SCAN sync ID: 28, bssidx: 0
[ 4401.110959] usb 1-1.4: new full-speed USB device number 11 using sunxi-ehci
[ 4401.231921] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 4580.997001] wl_run_escan: LEGACY_SCAN sync ID: 29, bssidx: 0
[ 4760.990583] wl_run_escan: LEGACY_SCAN sync ID: 30, bssidx: 0
[ 4941.028289] wl_run_escan: LEGACY_SCAN sync ID: 31, bssidx: 0
[ 5120.978417] wl_run_escan: LEGACY_SCAN sync ID: 32, bssidx: 0
[ 5300.974836] wl_run_escan: LEGACY_SCAN sync ID: 33, bssidx: 0
[ 5480.970450] wl_run_escan: LEGACY_SCAN sync ID: 34, bssidx: 0
Your host keeps resetting the USB subsystem because of a condition consistent with excessive electromagnetic interference. This is usually caused by poorly shielded USB cables, but it can also be caused by a poor quality USB peripheral or, more rarely, by faulty hardware on the host machine.
If you have anything else connected to the host USB other than the printer, unplug it and see if that helps. If not, try disconnecting all USB devices from the host, reboot the host, and just let it sit for a few hours with no USB connections. Then check dmesg again for this error. If it continues to appear, that would suggest faulty hardware.
Only thing connected is the printer. When you say hardware are you referring to the speeder pad or the main board. I ask because before I switched to klipper I had the printer hooked directly to my computer through USB and it would do what I assume is the Marlin equivalent of lost MCU by just stopping mid print. I’ve had a suspicion since day 1 that the mainboard was faulty.
If the speeder pad still resets the USB connection like that without anything connected to it, then the problem would most likely be in the speeder pad itself. If the USB resets only occur when the printer (and no other USB peripherals) are connected, then that would suggest that the printer (i.e. the mainboard) is itself the faulty peripheral.
If that is the case, and if you’re comfortable with a soldering iron, you could try checking the physical USB port on the MKS board and resoldering it.
Problem with troubleshooting the pad is it doesn’t boot klipper unless it’s connected to the printer. Just says printer is not ready and then says mcu unable to connect.
Can you ssh into it? How did you get the dmesg output?
Ssh through moba
I don’t know what moba is, but I presume it doesn’t depend on Klipper. You should be able to ssh into it and check dmesg even without Klipper in ready state (or even running at all for that matter).
This is what I get without the printer being connected.
[ 2.816902] sunxi-mmc sdc2: No vq18sw regulator found
[ 2.823567] sunxi-mmc sdc2: set host busy
[ 2.828192] mmc:failed to get gpios
[ 2.832909] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.862514] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.890519] usb 1-1.1: new high-speed USB device number 3 using sunxi-ehci
[ 2.890570] sunxi-mmc sdc2: detmode:alway in(non removable)
[ 2.890784] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.893308] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.894406] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.894738] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[ 2.894749] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[ 2.894761] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[ 2.894772] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[ 2.894784] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[ 2.894795] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[ 2.894876] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.894964] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.897466] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.898849] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.48 2020-9-15 16:01)
[ 2.899002] sunxi-mmc sdc0: ctl-spec-caps 8
[ 2.899156] sunxi-mmc sdc0: No vmmc regulator found
[ 2.899161] sunxi-mmc sdc0: No vqmmc regulator found
[ 2.899166] sunxi-mmc sdc0: No vdmmc regulator found
[ 2.899171] sunxi-mmc sdc0: No vd33sw regulator found
[ 2.899175] sunxi-mmc sdc0: No vd18sw regulator found
[ 2.899180] sunxi-mmc sdc0: No vq33sw regulator found
[ 2.899185] sunxi-mmc sdc0: No vq18sw regulator found
[ 2.900139] sunxi-mmc sdc0: set host busy
[ 2.900223] sunxi-mmc sdc0: Got CD GPIO
[ 2.901181] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.901207] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 2.918519] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.919767] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.932783] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing LEGACY(SDR12) dt B
[ 2.934922] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[ 2.935348] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[ 2.935646] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[ 2.935829] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[ 2.936101] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[ 2.936245] sunxi_mmc_get_hs400_cmd_dly,222
[ 2.936253] sunxi-mmc sdc2: failed to get HS400_cmd used default
[ 2.936299] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[ 2.936439] sunxi_mmc_get_hs400_cmd_dly,222
[ 2.936447] sunxi-mmc sdc2: failed to get HS400_cmd used default
[ 2.936591] mmc0: new HS400 MMC card at address 0001
[ 2.938895] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.939641] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.942548] sunxi-mmc sdc0: detmode:gpio polling
[ 2.943769] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.48 2020-9-15 16:01)
[ 2.943895] sunxi-mmc sdc1: ctl-spec-caps 8
[ 2.944048] sunxi-mmc sdc1: No vmmc regulator found
[ 2.944053] sunxi-mmc sdc1: No vqmmc regulator found
[ 2.944058] sunxi-mmc sdc1: No vdmmc regulator found
[ 2.944063] sunxi-mmc sdc1: No vd33sw regulator found
[ 2.944067] sunxi-mmc sdc1: No vd18sw regulator found
[ 2.944072] sunxi-mmc sdc1: No vq33sw regulator found
[ 2.944077] sunxi-mmc sdc1: No vq18sw regulator found
[ 2.944331] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.944529] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.946038] sunxi-mmc sdc1: set host busy
[ 2.946149] mmc:failed to get gpios
[ 2.946946] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.946975] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 2.949051] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 2.952298] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 2.974522] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.994516] sunxi-mmc sdc1: detmode:manually by software
[ 2.996439] sunxi_led_probe()1690 - start
[ 2.996506] sunxi_get_str_of_property()1549 - failed to get the string of propname led_regulator!
[ 2.998796] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 2.999631] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 2.999656] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.002159] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.004061] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.005603] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.006426] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.007254] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.007281] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.008378] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.008463] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 3.026524] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.047604] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.048714] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.048736] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.051387] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.053578] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.054671] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.055770] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.056868] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.056897] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.057997] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.058093] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 3.076689] sunxi_led_probe()1782 - finish
[ 3.077608] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.078283] usbcore: registered new interface driver usbhid
[ 3.078286] usbhid: USB HID core driver
[ 3.082532] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.083657] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[ 3.083665] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[ 3.083672] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[ 3.083679] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[ 3.083687] sun50iw10p1-pinctrl pio: expect_func as:pcm0, but muxsel(3) is func:h_i2s0
[ 3.084384] sunxi-daudio daudio0: regulator missing or invalid
[ 3.088160] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[ 3.090141] [sunxi_card_init] card init finished.
[ 3.092602] sunxi-codec-machine sndcodec: sun50iw10codec ↔ 5096000.cpudai-controller mapping ok
[ 3.096962] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
[ 3.097651] u32 classifier
[ 3.097654] Actions configured
[ 3.097890] Initializing XFRM netlink socket
[ 3.105312] NET: Registered protocol family 10
[ 3.108142] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.109783] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.109814] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.112710] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.115300] NET: Registered protocol family 17
[ 3.115457] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.116394] 8021q: 802.1Q VLAN Support v1.8
[ 3.116547] Key type dns_resolver registered
[ 3.117091] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.118729] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.118738] random: fast init done
[ 3.120364] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.120389] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.121499] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.121615] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 3.150543] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.167686] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 3.167695] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
[ 3.168165] cpu cpu1: opp_list_debug_create_link: Failed to create link
[ 3.168172] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[ 3.168231] cpu cpu2: opp_list_debug_create_link: Failed to create link
[ 3.168237] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[ 3.168294] cpu cpu3: opp_list_debug_create_link: Failed to create link
[ 3.168300] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[ 3.170090] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.7 (r)
[ 3.170105] ======== dhd_wlan_init_plat_data ========
[ 3.170113] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[ 3.170116] dhd_wlan_init_gpio: oob_irq=15, oob_irq_flags=0x4084
[ 3.170118] dhd_wifi_platform_load: Enter
[ 3.170162] Power-up adapter ‘DHD generic adapter’
[ 3.170303] wifi_platform_set_power = 1
[ 3.170306] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.170577] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[ 3.170945] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[ 3.173736] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.176953] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.176968] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.180581] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.184928] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.188148] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.191367] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.250523] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.256413] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.262282] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.272863] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.285812] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.486498] wifi_platform_bus_enumerate device present 1
[ 3.486503] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 3.486506] ======== Card detection to detect SDIO card! ========
[ 3.607149] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 3.607294] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 3.607486] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 3.609089] mmc2: new high speed SDIO card at address 0001
[ 3.626664] bcmsdh_register: register client driver
[ 3.626901] bcmsdh_sdmmc_probe: Enter num=1
[ 3.627037] bcmsdh_sdmmc_probe: Enter num=2
[ 3.627040] bus num (host idx)=2, slot num (rca)=1
[ 3.627043] found adapter info ‘DHD generic adapter’
[ 3.627102] sdioh_attach: set sd_f2_blocksize 256
[ 3.627134] sdioh_attach: sd clock rate = 0
[ 3.627523] dhdsdio_probe : no mutex held. set lock
[ 3.627641] F1 signature read @0x18000000=0x1541a9a6
[ 3.630091] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 3.630955] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 3.631088] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 3.631280] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 3.633721] dhd_attach(): thread:dhd_watchdog_thread:447 started
[ 3.633808] dhd_attach(): thread:dhd_dpc:448 started
[ 3.633907] dhd_attach(): thread:dhd_rxf:449 started
[ 3.633956] dhd_deferred_work_init: work queue initialized
[ 3.634003] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 3.634183] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 3.642273] Dongle Host Driver, version 1.579.77.41.7 (r)
[ 3.644968] wl_ext_iapsta_attach_netdev: bssidx=0
[ 3.644974] Register interface [wlan0] MAC: b8:2d:28:1d:f7:54
[ 3.645025] dhd_wl_ioctl: returning as busstate=0
[ 3.645029] dhd_bus_devreset: == Power OFF ==
[ 3.645244] bcmsdh_oob_intr_unregister: Enter
[ 3.645246] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.645269] dhd_txglom_enable: enable 0
[ 3.645272] dhd_conf_set_txglom_params: txglom_mode=multi-desc, use_rxchain=0
[ 3.645275] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 3.645278] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 3.645281] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 3.645284] dhd_bus_devreset: WLAN OFF DONE
[ 3.645317] wifi_platform_set_power = 0
[ 3.645320] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.645720] dhdsdio_probe : the lock is released.
[ 3.645977] dhd_module_init: Exit err=0
[ 3.647418] sunxi_ctp_startup: ctp_power_io is invalid.
[ 3.647470] deviceless supply vcc-ctp not found, using dummy regulator
[ 3.647645] get ctp_screen_max_x is fail, -22
[ 3.759077] sunxi_i2c_drv_core_process()972 - [i2c6] Timeout when sending 9th SCL clk
[ 3.759129] i2c_sunxi_drv_complete()1146 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x14)
[ 3.759135] 0x07081600: 01011001 00000001 00002800 0001ffff
[ 3.759140] 0x07081610: 00008040 00010004 00010010 00000000
[ 3.759213] sunxi_i2c_drv_core_process()972 - [i2c6] Timeout when sending 9th SCL clk
[ 3.759263] i2c_sunxi_drv_complete()1146 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x5d)
[ 3.759268] 0x07081600: 11011001 00000001 0000bb00 00000001
[ 3.759274] 0x07081610: 00008040 00010004 00010010 00000000
[ 3.759526] sunxi_i2c_do_xfer()1923 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[ 3.760046] detect ret 2
[ 3.760048] ======detect ok !=====
[ 3.760660] GTP I2C Address:0x5d
[ 3.760930] create_singlethread_workqueue goodix_resume.
[ 3.761089] create_singlethread_workqueue goodix_wq.
[ 3.891375] X_MAX = 800,Y_MAX = 480,TRIGGER = 0x01
[ 3.891376] input: gt9xx_ts as /devices/virtual/input/input4
[ 3.898617] IC Version: 911_1060
[ 3.898618] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
[ 3.900056] usb0-vbus: disabling
[ 3.900084] ALSA device list:
[ 3.900087] #0: audiocodec
[ 4.432200] EXT4-fs (mmcblk0p5): couldn’t mount as ext3 due to feature incompatibilities
[ 4.542938] hub 1-1.1:1.0: USB hub found
[ 4.547795] hub 1-1.1:1.0: 4 ports detected
[ 4.674874] EXT4-fs (mmcblk0p5): 4 orphan inodes deleted
[ 4.680842] EXT4-fs (mmcblk0p5): recovery complete
[ 4.696802] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 4.705990] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 4.713687] devtmpfs: mounted
[ 4.717320] Freeing unused kernel memory: 448K
[ 4.842527] usb 1-1.1.2: new high-speed USB device number 4 using sunxi-ehci
[ 4.854631] systemd[1]: System time before build time, advancing clock.
[ 4.873013] systemd[1]: Failed to look up module alias ‘autofs4’: Function not implemented
[ 4.888822] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.905394] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.932108] systemd[1]: Detected architecture arm64.
[ 4.959120] systemd[1]: Set hostname to .
[ 5.070668] usb 1-1.1.2: reset high-speed USB device number 4 using sunxi-ehci
[ 5.222380] r8152 1-1.1.2:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[ 5.263790] r8152 1-1.1.2:1.0 (unnamed net_device) (uninitialized): Random ether addr 62:c1:83:ea:ad:4a
[ 5.277294] r8152 1-1.1.2:1.0 eth0: v1.08.9
[ 5.522678] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.530565] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 5.544684] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 5.556092] systemd[1]: Created slice system-getty.slice.
[ 5.578665] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.586997] systemd[1]: Created slice system-modprobe.slice.
[ 5.606626] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.614917] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.635368] systemd[1]: Created slice User and Session Slice.
[ 5.655074] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.682831] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 5.696163] systemd[1]: Reached target Remote File Systems.
[ 5.718639] systemd[1]: Reached target Slices.
[ 5.738667] systemd[1]: Reached target Swap.
[ 5.759156] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.783973] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 5.794036] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.815574] systemd[1]: Listening on Journal Socket.
[ 5.835592] systemd[1]: Listening on udev Control Socket.
[ 5.855163] systemd[1]: Listening on udev Kernel Socket.
[ 5.875130] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.884674] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
[ 5.900434] systemd[1]: Mounting Kernel Debug File System…
[ 5.923184] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 5.937981] systemd[1]: Starting Journal Service…
[ 5.959066] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 5.977706] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 5.998782] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 6.014097] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 6.040688] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 6.068699] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 6.096596] systemd[1]: Starting Load Kernel Module ramoops…
[ 6.119252] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 6.132416] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.149911] systemd[1]: Starting Load Kernel Modules…
[ 6.176200] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.204330] systemd[1]: Starting udev Coldplug all Devices…
[ 6.232891] systemd[1]: Started Journal Service.
[ 6.457109] systemd-journald[1147]: Received client request to flush runtime journal.
[ 6.484342] systemd-journald[1147]: File /var/log/journal/2dc89acf896c426b888d4b89327fdda8/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 6.998614]
[ 7.529993] systemd-journald[1147]: Failed to read journal file /var/log/journal/2dc89acf896c426b888d4b89327fdda8/user-1000.journal for rotation, trying to move it out of the way: Text file busy
[ 8.349641] systemd-journald[1147]: Failed to set ACL on /var/log/journal/2dc89acf896c426b888d4b89327fdda8/user-1000.journal, ignoring: Operation not supported
[ 8.458302] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.265385] sunxi-bt soc@03000000:bt@0: block state already is 1
[ 13.255618] random: crng init done
[ 13.255630] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.764099] dhd_open: Enter ffffffc039c58080
[ 13.764110] dhd_open : no mutex held. set lock
[ 13.764122]
[ 13.764128] wl_ext_iapsta_attach_netdev: bssidx=0
[ 13.764133] wl_android_wifi_on in 1
[ 13.764139] wl_android_wifi_on in 2: g_wifi_on=0
[ 13.764144] wifi_platform_set_power = 1
[ 13.764149] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 13.764436] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[ 13.766174] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[ 14.240619] sdio_reset_comm():
[ 14.240650] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.242875] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.244022] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.284677] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 14.290998] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 14.297276] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 14.308937] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 14.323191] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 14.691649] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.691880] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.692119] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 14.692244] sdioh_start: set sd_f2_blocksize 256
[ 14.692526]
[ 14.692635] F1 signature read @0x18000000=0x1541a9a6
[ 14.695450] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 14.696475] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 14.696595] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 14.697503] dhd_conf_read_config: Ignore config file /lib/firmware/config.txt
[ 14.697530] Final fw_path=/lib/firmware/fw_bcm43438a1.bin
[ 14.697534] Final nv_path=/lib/firmware/nvram.txt
[ 14.697538] Final clm_path=/lib/firmware/clm.blob
[ 14.697542] Final conf_path=/lib/firmware/config.txt
[ 14.700319] dhd_os_open_image: /lib/firmware/fw_bcm43438a1.bin (407537 bytes) open success
[ 14.767893] dhd_os_open_image: /lib/firmware/nvram.txt (948 bytes) open success
[ 14.768578] NVRAM version: AP6212A_NVRAM_V1.0.1_20160606
[ 14.778586] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 14.853338] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 14.853447] bcmsdh_oob_intr_register: HW_OOB irq=15 flags=0x4
[ 14.871768] Disable tdls_auto_op failed. -1
[ 14.871779] dhd_preinit_ioctls: Set tcpack_sup_mode 0
[ 14.871785] dhd_tcpack_suppress_set 352: already set to 0
[ 14.872337] dhd_apply_default_clm: Ignore clm file /lib/firmware/clm.blob
[ 14.875723] Firmware up: op_mode=0x0005, MAC=b8:2d:28:1d:f7:54
[ 14.880119] dhd_preinit_ioctls Set scancache failed -23
[ 14.895283] Driver: 1.579.77.41.7 (r)
CLM: 7.11.15
[ 14.895711] dhd_txglom_enable: enable 1
[ 14.895720] dhd_conf_set_txglom_params: txglom_mode=multi-desc, use_rxchain=0
[ 14.895726] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
[ 14.895731] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 14.895735] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 14.895746] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[ 14.897369] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 14.899936] dhd_pno_init: Support Android Location Service
[ 14.899955] dhd_preinit_ioctls: SensorHub diabled 0
[ 14.900878] dhd_preinit_ioctls failed to set ShubHub disable
[ 14.901857] dhd_ndo_get_version: failed, retcode = -23
[ 14.902846] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 14.902854] failed to get wnm_bsstrans_resp
[ 14.903706] failed to set WNM capabilities
[ 14.928995] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[ 14.929079] dhd_conf_set_country: set country CN, revision 0
[ 14.932641] Country code: CN (CN/0)
[ 14.935880] wl_android_wifi_on: Success
[ 14.950306] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[ 14.969639] dhd_open : the lock is released.
[ 14.969657] dhd_open: Exit ret=0
[ 15.132579] P2P interface registered
[ 15.132599] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc02f819c80, wdev->net: (null)
[ 15.260314] WLC_E_IF: NO_IF set, event Ignored
[ 15.262982] P2P interface started
[ 15.282372] wl_run_escan: LEGACY_SCAN sync ID: 0, bssidx: 0
[ 16.386428] Connecting with f8:9b:6e:42:bb:14 ssid “NotYours1”, len (9) channel=10
[ 16.427844] wl_bss_connect_done succeeded with f8:9b:6e:42:bb:14
[ 16.455072] wl_bss_connect_done succeeded with f8:9b:6e:42:bb:14 vndr_oui: 00-10-18
[ 20.918337] wl_run_escan: LEGACY_SCAN sync ID: 1, bssidx: 0```
MobaXterm… It’s like putty… It’s an ssh portal.
So that second dmesg log isn’t showing the error, but you may have to let it stew for a while. Even with the printer connected it took almost 8 minutes before the connection became unstable and more than 30 minutes before it started throwing the EMI error.
Let me riddle you this. I just stumbled across a post about emi being caused by running sesperate power supplies to the printer and the pad. Could be a ground loop problem? A couple weeks ago I ran the pad off the power supply from my v400 which is factory wired into the printers power supply and it ran just fine. I would assume that there was a stable ground within the other printer…
That’s conceivable. It still points to a hardware problem, the only question is whether it’s a faulty unit or a design defect that affects the entire product. It could also be the pad is running off a noisy power supply, though if that were the culprit, you would still expect to see the USB resets even without the printer connected.
On second thought though, perhaps there needs to be USB data transfer before the resets will be triggered. If your pad runs for at least an hour without throwing those USB errors, try plugging something like a thumb drive into it and copying files back and forth for a little while and see if that triggers any USB errors.
I will try that. You have no idea how much I appreciate all your help.
Please use the preformated text feature of the editor to paste in your results.
Format
Wired in the power to the 12/24 on the board like it is on the V400 and I am now getting this message.
[   20.000742] wl_run_escan: LEGACY_SCAN sync ID: 1, bssidx: 0
[   24.035259] usb 1-1.4: new full-speed USB device number 5 using sunxi-ehci
[   24.190707] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
pi@speeder-pad:~/klipper$
