Ok, I’ve got something I guess, because I’ve made it running. It will take some time still to go deeper, but want to share something now, and maybe get some help further.
I went back to your idea about the CHIP ID, it bothered me somehow. Of course it was my fault, instead of deselecting the USB serial number from CHIPID I just disabled extra low-level configuration - don’t kill me please, that’s what happens when I read your instructions before morning coffee
. But that got me to following that path and trying to fix getting that chip id
So, debugging further got me that it probably gets stuck on:
rom_get_sys_info_fn func = rom_func_lookup(ROM_FUNC_GET_SYS_INFO);
uint8_t data[9 * 4];
func(data, 9, SYS_INFO_CHIP_INFO);
I’ve made a lot of changes now:
the *out_buffer was uint8_t, I adjusted this function to use it exactly as in the SDK 2.2
void
bootrom_read_unique_id(uint8_t *out, uint32_t maxlen)
typedef int (*rom_get_sys_info_fn)(uint32_t *out_buffer, uint32_t out_buffer_word_size, uint32_t flags);
union {
uint32_t words[9];
uint8_t bytes[9 * 4];
} data;
__unused int rc = func(data.words, 9, SYS_INFO_CHIP_INFO);
int i;
for (i = 0; i < PICO_UNIQUE_BOARD_ID_SIZE_BYTES; i++)
out[i] = data.bytes[PICO_UNIQUE_BOARD_ID_SIZE_BYTES - 1 + 2 * 4 - i];
I also changed the rom_func_lookup slightly, I added the pico_processor_state_is_nonsecure, from SDK, and used it in the rom_func_lookup. Probably unnecessary, but I was doing step by step adjustments to the SDK, so I thought that maybe in some situations this may be important.
static bool pico_processor_state_is_nonsecure(void) {
#ifndef __riscv
// todo add a define to disable NS checking at all?
// IDAU-Exempt addresses return S=1 when tested in the Secure state,
// whereas executing a tt in the NonSecure state will always return S=0.
uint32_t tt;
pico_default_asm_volatile (
“movs %0, #0\n”
“tt %0, %0\n”
: “=r” (tt) : : “cc”
return !(tt & (1u << 22));
#else
// NonSecure is an Arm concept, there is nothing meaningful to return
// here. Note it’s not possible in general to detect whether you are
// executing in U-mode as, for example, M-mode is classically
// virtualisable in U-mode.
return false;
#endif
static void *
rom_func_lookup(uint32_t code)
typedef void (rom_table_lookup_fn)(uint32_t code, uint32_t mask);
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored “-Warray-bounds”
rom_table_lookup_fn rom_table_lookup = (rom_table_lookup_fn)
(uintptr_t)(uint16_t)(BOOTROM_TABLE_LOOKUP_OFFSET);
#pragma GCC diagnostic pop
if (pico_processor_state_is_nonsecure()) {
return rom_table_lookup(code, RT_FLAG_FUNC_ARM_NONSEC);
} else {
return rom_table_lookup(code, RT_FLAG_FUNC_ARM_SEC);
And in bootrom_constants.h we have:
// todo remove this (or #ifdef it for A1/A2)
#define BOOTROM_IS_A2() ((*(volatile uint8_t *)0x13) == 2)
#define BOOTROM_WELL_KNOWN_PTR_SIZE (BOOTROM_IS_A2() ? 2 : 4)
Which I changed to simply
#define BOOTROM_WELL_KNOWN_PTR_SIZE 2
Also I updated all the hardware/regs to SDK2.2 for RP2350.
As a result. my usb-devices now beautifully contain:
T: Bus=01 Lev=02 Prnt=03 Port=01 Cnt=01 Dev#= 32 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=02(commc) Sub=00 Prot=00 MxPS=16 #Cfgs= 1
P: Vendor=1d50 ProdID=614e Rev=01.00
S: Manufacturer=Hello
S: Product=rp2350
S: SerialNumber=C7CA988AA511E8A8
C: #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=255ms
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
//EDIT, now I made a fresh repo clone, and changed ONLY BOOTROM_WELL_KNOWN_PTR_SIZEand it works!
