SV08 Mainline PA3 used too many times in config
Printer Model: SV08
MCU / Printerboard:
I’m switching a default Sovol SV08 to mainline Klipper using Rappetor’s Github steps, however when using ther printer.cfg and modifying the fan pins so PA1 powers the enclosure fan and PA2 does silence it’s fan when not needed, however after applying these changes I get on the klipper screen/log that PA3 is being used too many times although I can’t find it defined in the printer.config file, can you point out what I’m not seeing? thanks
klippy.log (257.5 KB)
Welcome WanderingRaven,
I’m unsure if I get you right!
[output_pin main_led]
pin = PA3
pwm = 1
value = 1
cycle_time = 0.010
Good luck, hcet14
First time here (line 1187):
pin = PA3
pwm = 1
value = 1
cycle_time = 0.010
then here (line 1879):
[led main_led]
white_pin = PA3
cycle_time = 0.010
hardware_pwm = False
initial_white = 1.0
That’s it, thank you I’ll try merging them into one and then it should work
