Printer Model: Voron 2.4 Stealthchanger
MCU / Printerboard: BTTMantra M8P, BTT EBB36 via CAN
klippy.zip (5.4 MB)
Hi everybody,
I am having Issues with my new Trianglelab Rapido Ace Hotend with PT1000.
Sometimes it takes up to 10 Minutes for the nozzle to settle to target temp via M109. Similar to:
This is the closest to my problem i can find online. It doesnt matter if i use the MAX31865 port oder the TH0 Port on the EBB36, sometimes the temp. settles within 1-2 minutes, and sometimes 10.
In the mentioned post this solution was provided:
[gcode_macro M109]
rename_existing: M109.1
{% set S = params.S|float %}
{% set actual_temp = printer.extruder.temperature|float %}
{% set max_fuzzy = S + 2 %}
M104 { rawparams }
{% if S != 0 %}
{% if actual_temp <= S %} TEMPERATURE_WAIT SENSOR=extruder MINIMUM={S}
{% else %} TEMPERATURE_WAIT SENSOR=extruder MAXIMUM={max_fuzzy} {% endif %}
Is there a way to combine this with the stealthchanger M109 macro replacement? :
[gcode_macro M109]
description: [T<index>] [S<temperature>]
Set tool temperature and wait.
T= Tool number, optional. If this parameter is not provided, the current tool is used.
S= Target temperature
{% if params.T is defined %}
{% set newparameters = "" %}
{% set newparameters = newparameters ~ " T="~params.T %}
{% if params.S is defined %}
{% set newparameters = newparameters ~ " TARGET="~params.S %}
SET_TOOL_TEMPERATURE WAIT=0 {newparameters}
{% else %}
M109.1 {rawparams}
I tried a few amateurish attempts, but of course it didnt work.
Thank you for reading…
