Thermal Runaway only when printing
I use Klipper on my Ender 3 Pro.
This setup worked for months without problems.
Suddenly whenever i print something after reaching about 2mm Z-Height (no matter what i print),
Klipper shuts down with a thermal runaway error.
When i heat the nozzle without printing i can keep the temperature for hours (when making sure its not reset to 0 after the timeout)
without getting any errors, also it hold the temperature just fine.
I already did a PID Tune but that did not help.
What can i do to figure out what the problem is, i dont want to randomly buy a new heater/thermistor without knowing that those are actuably broken…
Hello @JappyJan !
Have you checked if the cables to the hotend are in proper shape, no lose connection, no broken cable.
Also, you may share the klippy log.
Hey just checked again, and yes all cables seem to be good, no loose contacts etc.
And here is my klippy.log
klippy.log (16.6 KB)
On what system is your Klipper running?
its a raspberry pi4 running raspbian (32 bit)
klipper was installed through KIAUH.sh
Does this support runtime logs like octoprint.log?
i dont know what you mean by that :confused:
i am not running octoprint, and i did not start with an octopi installation but with a clean raspbian installation.
The log you posted doesn’t contain an error. We need a log with the error to diagnose. In my experience these errors are always hardware like a loose pin or partially broken wire, or the hotend or bed can’t maintain temperature when the cooling fan turns on. A log with the error would make it possible to determine the likely cause.
Like Jake said, I’ve had the same error if the thermistor wire comes loose.
Sorry for the late reply, been busy a lot…
Here is a link that would most definitely contain logs from a failed print
klippy.log (5.8 MB)
Looking at your log it seems:
  • You are requesting a bed temperature of 45°C
  • Then you increase bed temperature to 110°C
  • Your bed heater struggles with reaching the target but does not manage to do so until Klipper errors out
Following questions:
  • You wrote that you get the error at Z=2mm: Do you start printing before the bed has reached its temperature?
  • Are you sure that a Ender 3 Pro bed even is able to reach and sustain 110°C (which is quite high for the standard Chinese beds)
