Thermocouple reader fault after temp is reached
Printer Model: CoreXY
MCU / Printerboard: Octopus Pro
klippy (7).log (242.4 KB)
I have extruder PT1000 connected on internal MAX on Octopus Pro. It show temperature without issues.
But it will crash when I set temperature close to maximum temp (like 250 on default settings). 248 is no issues, 250 crash with message about thermocouple.
It looks that temperature swing little over max_temp and it will crash klipper down.
max_temp = 250
You have limited your temp to max 250°C
yes, but system should be able to work with required temp set to max_temp (or it is not max_temp) or produce relevant error and not this one.
Even the swing has to be below max_temp.
