Ошибка клиппера TMC 'stepper_y'
Printer Model: Kingroon kp3s pro v2
MCU / Printerboard:
klippy.log (2.6 MB)
The printer stops while printing and this error appears
“TMC ‘stepper_y’ reports error: DRV_STATUS: 001701c3 otpw=1(OvertempWarning!) ot=1(OvertempError!) ola=1(OpenLoad_A!) olb=1(OpenLoad_B!) t120=1 cs_actual=23 Once the underlying issue is corrected, use the “FIRMWARE_RESTART” command to reset the firmware, reload the config, and restart the host software. Printer is shutdown”
Can you please help me fix it?
Hello @KvadroDim !
Please write in English.
We can read the error message, but not what you want.
Hello, I translated everything into English
The drivers get way too hot.
TMC driver need cooling with at least a heatsink - much better an additional cooling by a fan.
Ok, thank you
Cooling might not be needed. I don’t know the printer, but I think the currents of your TMC2209s are quite high. The extruder might be ok, but the rest? Have a look e.g. here Klipper-KingRoon-Printers/KP3S_PRO_V2/tmc.cfg at main · nehilo/Klipper-KingRoon-Printers · GitHub
Good luck, hcet14
