Printer Model: Custom
MCU / Printerboard: SKR 3 EZ
Dear Kevin or whoever has the knowledge:),
I have a few questions about the TMC5160 settings for Klipper, mainly around the customization of the parameter set.
After downloading the excel sheet provided by Trinamic to find the correct values for the parameters, I came across some parameters in the excel sheet but, not among the customizable parameters from within printer.cfg. However, please correct me if I am wrong.
-As far as I understand, the EZ5160 drivers (like most 5160 it seems) have 0.075 Ohm Sense resistors in them. But, the excel sheet, with 12Mhz for fCLK, 48V, 0.0015 mH inductivity and 2.5A peak current gives me 0.108 Ohms as Rsense. Now, the only way to change Rsense to 0.075 Ohm seems to be to change CS to 23 instead of the default 31. I can not find a way to change this parameter on the drivers, is there a way to change this, or am I missing something?
- The calculation sheet that I downloaded from Trinamic website from 5160 documentation does not include two Rsense values depending on Vsense=0 and Vsense=1. Is there some other calc sheet used for Klipper and where exactly can we control Vsense value?
Thank you.
