Touchscreen does not display menu
I am new to klipper, i have installed the touch screeen correctly as i get an output on boot but dont get the menu display all i get is a black screen with a solid cursor at the top left of the screen
i am using a BTT Mant e3ez with a CB1 and a TFT35SPI V2.1
Please help with any advice
Are you are using the standard CB1 software image?
I see a note at the BTT wiki that “Currently, it only supports CB1. V2.2.0 and earlier OS do not support TFT35 SPI. Please use V2.2.1 and later OS.”
There is also information on editing a configuration file on the CB1
currently using version 3 unless you think its worth trying an earlier version
i also found that if i am in the klipper web interface and i tap on the touch screen messages pop up on the web interface as though i pressed on a button
