Printer Model: Elegoo OrangeStorm Giga
MCU / Printerboard:
klippy_log.txt (221.4 KB)
crowsnest_log.txt (24.5 KB)
I am only able to get 2 cams to work on the OSG, it has 2 usb ports, but I connected a hub. I think my crowsnest file is set up correctly, and my printer can detect all 3 cameras, but one on the hub shows no signal. If I disconnect the camera from the hub that is working, then the one that said no signal works. if I then plug the 1st camera back in it says no signal until the other one is unplugged. then it works again. also I noticed when i restart crowsnest what ever of the 2 cameras I first click on works and the other says no signal. It seems like I am close. I don’t know if it is me not knowing how to do this, my printer, my version of crowsnest, or other software, or my hub. I am also not sure if I can upgrade crowsnest or ustreamer on the printer. I don’t want to break it. any help would be greatly appreciated.
thanks
