Printer Model: my own design CoreXY, working well for over 6 years now.
MCU / Printerboard: MKS SBase 1.3, smoothie-like board, working well for over 3 years now.
Host / SBC Raspberry Pi 4, working well for over a year now.
I had a SD card failure on the Pi and did a full new install, as the backups I had were on my old laptop, on which the harddrive failed. So, fresh install, no other changes, and I started tuning with the manual as the guide. Everything goes well, no issues, except for the resonance compensation. I follow the instructions to the letter, as I did first time around a year ago, when I switched over from Marlin to Klipper. But printing the ringing tower with the tuning tower command to slowly increase the max accel, it just doesn’t do that. The item prints, I can count the ringing and I have meanwhile set the frequencies and such in the printer.cfg and that works. But why doesn’t the system increase the max accel as it should? I’ve now printed 5 separate towers manually increasing the max accel in the printer.cfg. Setting it to 9k (allowing for all values in the tower print) makes it print at 9k the whole tower, setting it to zero or commenting the command out (as suggested to me on Fakebook) doesn’t work, Klipper doesn’t allow that. Cura is set to not bother with accelleration, so Klipper is free to run that. What can I check, what could cause this not to work?
Hugo
I’m sorry I had some trouble getting Windoze to accept the klippy log download. I’m not very good at this. Which is also why I have a hard time structuring data / info. I’m a story teller, not an engineer. The file should be attached, now.
Just a funny thought. Soon after upgrading from Marlin2.0 to Klipper, I changed the X-axle with extruder cart from my previous design at 1,7 kg, to my new design at 0,7 kg. Never changed anything in the set-up. The heavy set-up maxed at 3500 mm/s2, could it be this new set-up only starts misbehaving above 7k, so outside of the reach of the original tuning tower command line? Is is weird to have a value like that higher than 7k?
I didn’t use that command in the last print, I am now making many prints manually raising the max accel value inbetween prints. As I didn’t see any changes in the ‘clevage’ occouring when I used the command. I don’t know what the klippy log records. Only the last print? Then it didn’t record the tuning tower command, as I used that a few times before to no avail and now working manually. I followed the instructions to the letter but there was no change between bottom and top of the printed tower.
This is where your log begins. Without a log showing the issue and maybe some pictures of a manual run versus tuning_tower there is not much that we can contribute.
Hi, I’ve meanwhile found out the tuning tower does work. It is just that my max accel can be a lot higher than 7k, while in the previous itteration of my printer it started widening the gap in the print at about 4k. So I ran that printer-variation at 3.5k. I’ve since lightened the moving bits, obviously with success… Because the gap in the tuning tower didn’t budge, I thought it didn’t work. Hence my question here.
So this is ‘solved’, now I only need to figure out why I have major layer shift issues since my fresh install. Different topic.
