Uncomment shaper_type and shaper_freq after using SHAPER_CALIBRATE AXIS?
Printer Model: Prusa i3MK3S+
MCU / Printerboard: Einsy Rambo
Host / SBC: RPi 5
Hello, I used TEST_RESONANCES AXIS=X followed by save_config for automatic Input Shaping of the X axis. Similarly, TEST_RESONANCES AXIS=Y followed by save_config for the Y-axis. When I opened the printer.cfg file, I found that at the bottom there are:
#*# [input_shaper]
#*# shaper_type_x = ei
#*# shaper_freq_x = 40.8
#*# shaper_type_y = mzv
#*# shaper_freq_y = 34.8
Is that all for Input Shaping?
Am I supposed to remove all the #*#? I recall that in other topics, we were told not to uncomment those green information under save_config but if the Input Shaping data are commented, how Klipper knows and uses the result of Input Shaping?
A confusion is that a youtuber used TEST_RESONANCES AXUS=X and TEST_RESONANCES AXUS=Y for Input Shaping. Then, he manually analyzed the data and created a [input_shaper] section in printer.cfg. Then, entered values for these four parameters without # at the beginning of each line.
That are the results of the measurement. Klipper puts those things there.
Also:
See line 2
Can Klipper read those measurements given that they have # at the beginning of the line?
What is #*# anyway?
@printeruser ,
The #*# is how Klipper denotes saved configuration variables. Klipper can and does read those lines without an issue.
Thank you for your info.
