Printer Model: voron 2.4
MCU / Printerboard: Octopus V1.1, STMF446xx
klippy (5).zip (644.4 KB)
Host / SBC Mainsail
Voron tap not working after upload and print.
…So i have upgraded my computer. Now i am unable to print with my Voron. Klippy attached. I am able to get to temp on bed/extruder and everything works. Once i hit upload and print, extruded drops from 260 degrees to 150. ( Is it possible for the voron tap to start at 150 do its homing and QGL then rise to 260. Instead of it needing to rise to 260 than drop to 150 than raise back to 260?)
Next it will tap the center of bed 6 times for some reason then sends Move out of range: 0.000 -25.000 10.000 [0.000] error, error sometimes changes Move out of range: 1.000 -3.500 10.000 [0.000] . I feel like its a G-code start print problem either in my CFG. file or its in orca,
I have the following G-Code in my Orca slicer:
; Filament gcode
M104 S0 ; Stops OrcaSlicer from sending temp waits separately
M140 S0
print_start EXTRUDER=[first_layer_temperature] BED=[first_layer_bed_temperature] CHAMBER=[chamber_temperature]
And my Start print G-code CFG.file
# A better print_start macro for v2/trident
## *** THINGS TO UNCOMMENT: ***
## Bed mesh (2 lines at 2 locations)
## Nevermore (if you have one)
## Z_TILT_ADJUST (For Trident only)
## QUAD_GANTRY_LEVEL (For V2.4 only)
## Beacon Contact logic (if you have one. 4 lines at 4 locations)
[gcode_macro PRINT_START]
# This part fetches data from your slicer. Such as bed, extruder, and chamber temps and size of your printer.
{% set target_bed = params.BED|int %}
{% set target_extruder = params.EXTRUDER|int %}
{% set target_chamber = params.CHAMBER|default("45")|int %}
{% set x_wait = printer.toolhead.axis_maximum.x|float / 2 %}
{% set y_wait = printer.toolhead.axis_maximum.y|float / 2 %}
## Uncomment for Beacon Contact (1 of 4 for beacon contact)
#SET_GCODE_OFFSET Z=0 # Set offset to 0
# Home the printer, set absolute positioning and update the Stealthburner LEDs.
STATUS_HOMING # Set LEDs to homing-mode
G28 # Full home (XYZ)
G90 # Absolute position
## Uncomment for bed mesh (1 of 2 for bed mesh)
#BED_MESH_CLEAR # Clear old saved bed mesh (if any)
# Check if the bed temp is higher than 90c - if so then trigger a heatsoak.
{% if params.BED|int > 90 %}
SET_DISPLAY_TEXT MSG="Bed: {target_bed}c" # Display info on display
STATUS_HEATING # Set LEDs to heating-mode
M106 S255 # Turn on the PT-fan
## Uncomment if you have a Nevermore.
#SET_PIN PIN=nevermore VALUE=1 # Turn on the nevermore
G1 X{x_wait} Y{y_wait} Z15 F9000 # Go to center of the bed
M190 S{target_bed} # Set the target temp for the bed
SET_DISPLAY_TEXT MSG="Heatsoak: {target_chamber}c" # Display info on display
TEMPERATURE_WAIT SENSOR="temperature_sensor chamber" MINIMUM={target_chamber} # Waits for chamber temp
# If the bed temp is not over 90c, then skip the heatsoak and just heat up to set temp with a 5 min soak
{% else %}
SET_DISPLAY_TEXT MSG="Soak for 5 min" # Display info on display
G4 P300000 # Wait 5 min for the bedtemp to stabilize
# Heat hotend to 150c. This helps with getting a correct Z-home.
SET_DISPLAY_TEXT MSG="Hotend: 150c" # Display info on display
M109 S150 # Heat hotend to 150c
## Uncomment for Beacon contact (2 of 4 for beacon contact)
#G28 Z METHOD=CONTACT CALIBRATE=1 # Calibrate z offset and beacon model
## Uncomment for Trident (Z_TILT_ADJUST)
#SET_DISPLAY_TEXT MSG="Leveling" # Display info on display
#STATUS_LEVELING # Set LEDs to leveling-mode
#Z_TILT_ADJUST # Level the printer via Z_TILT_ADJUST
#G28 Z # Home Z again after Z_TILT_ADJUST
## Uncomment for V2.4 (Quad gantry level AKA QGL)
#QUAD_GANTRY_LEVEL # Level the printer via QGL
#G28 Z # Home Z again after QGL
## Uncomment for bed mesh (2 of 2 for bed mesh)
#SET_DISPLAY_TEXT MSG="Bed mesh" # Display info on display
#STATUS_MESHING # Set LEDs to bed mesh-mode
#BED_MESH_CALIBRATE # Start the bed mesh (add ADAPTIVE=1) for adaptive bed mesh
## Uncomment for Beacon Contact (3 of 4 for beacon contact)
#G28 Z METHOD=CONTACT CALIBRATE=0 # Calibrate z offset only with hot nozzle
# Heat up the hotend up to target via data from slicer
SET_DISPLAY_TEXT MSG="Hotend: {target_extruder}c" # Display info on display
M107 # Turn off partcooling fan
M109 S{target_extruder} # Heat the hotend to set temp
## Uncomment for Beacon Contact (4 of 4 for beacon contact)
#SET_GCODE_OFFSET Z=0.06 # Add a little offset for hotend thermal expansion
# Get ready to print by doing a primeline and updating the LEDs
SET_DISPLAY_TEXT MSG="Printer goes brr" # Display info on display
STATUS_PRINTING # Set LEDs to printing-mode
G0 X{x_wait - 50} Y4 F10000 # Go to starting point
G0 Z0.4 # Raise Z to 0.4
G91 # Incremental positioning
G1 X100 E20 F1000 # Primeline
I have completed a fresh calibrate for the homing.
I have tried a different G-code start print macro.
It must be something simple!
I really could use some help. thanks in advance
