Wait Temperature issue
Hi there,
i want to set and wait temperature, but i’m having issue, i set correctly but i’m having unable to parse error.
this is my start gcode
[gcode_macro START_PRINT_ADAPTIVE]
  SET_HEATER_TEMPERATURE HEATER=heater_bed TARGET={first_layer_bed_temperature};
  TEMPERATURE_WAIT SENSOR=heater_bed MINIMUM={first_layer_bed_temperature};
	G90 ; Set all axes to absolute
	M82; set extruder to absolute
	G21; Set all in mm
	G28 ;Home
	BED_MESH_CALIBRATE ADAPTIVE=1;
  G28;
  SET_HEATER_TEMPERATURE HEATER=extruder TARGET={first_layer_temperature}
  TEMPERATURE_WAIT SENSOR=extruder MINIMUM={first_layer_temperature}
	G1 X0 Y0 F3000;
	G1 X-3.50 Y20 Z0.3 F2000.0 ; Move to start position
	G1 X-3.50 Y100.0 Z0.3 F1500.0 E15 ; Draw the first line
	G1 X-1.50 Y100.0 Z0.3 F2000.0 ; Move to side a little
	G1 X-1.50 Y20 Z0.3 F1500.0 E30 ; Draw the second line
	G92 E0;
i’m using superslicer to slice model and first_layer_temperature is on the gcode.
Hello @Nesquirt !
You read this before you deleted it?
grafik
Please do again in the correct sub-forum (General Discussion)
