Set and Wait temp issue
Hi there,
i want to set and wait temperature, but i’m having issue, i set correctly but i’m having unable to parse error (on the first two line of the gcode), i cant go over.
this is my start gcode
[gcode_macro START_PRINT_ADAPTIVE]
  SET_HEATER_TEMPERATURE HEATER=heater_bed TARGET={first_layer_bed_temperature};
  TEMPERATURE_WAIT SENSOR=heater_bed MINIMUM={first_layer_bed_temperature};
	G90 ; Set all axes to absolute
	M82; set extruder to absolute
	G21; Set all in mm
	G28 ;Home
	BED_MESH_CALIBRATE ADAPTIVE=1;
  G28;
  SET_HEATER_TEMPERATURE HEATER=extruder TARGET={first_layer_temperature}
  TEMPERATURE_WAIT SENSOR=extruder MINIMUM={first_layer_temperature}
	G1 X0 Y0 F3000;
	G1 X-3.50 Y20 Z0.3 F2000.0 ; Move to start position
	G1 X-3.50 Y100.0 Z0.3 F1500.0 E15 ; Draw the first line
	G1 X-1.50 Y100.0 Z0.3 F2000.0 ; Move to side a little
	G1 X-1.50 Y20 Z0.3 F1500.0 E30 ; Draw the second line
	G92 E0;
i’m using superslicer to slice model and first_layer_temperature is available on the gcode, i checked
in superslicer i also set klipper gcode flavor.
If I hardcode the temperature it works, only with variables i have error
SET_HEATER_TEMPERATURE HEATER=heater_bed TARGET=70;
this is my printer.cfg
# This file contains common pin mappings for the BIGTREETECH SKR V1.4
# board. To use this config, the firmware should be compiled for the
# LPC1768 or LPC1769(Turbo).
#[include PIS.cfg]
[include macro.cfg]
[exclude_object]
[stepper_x]
step_pin: P2.2
dir_pin: !P2.6
enable_pin: !P2.1
microsteps: 32
rotation_distance: 40
#full_steps_per_rotation: 200
endstop_pin: P1.29
position_endstop: -12.90
position_max: 260
position_min: -12.90
homing_speed: 100
[stepper_y]
step_pin: P0.19
dir_pin: P0.20
enable_pin: !P2.8
microsteps: 32
endstop_pin: P1.28
position_endstop: -22.70
position_max: 230
position_min: -22.70
homing_speed: 100
step_pin: P0.22
dir_pin: !P2.11
enable_pin: !P0.21
microsteps: 32
rotation_distance: 8
position_max: 200
homing_speed: 10
second_homing_speed: 10
position_min: -6.0
[stepper_z1]
step_pin: P1.15
dir_pin: !P1.14
enable_pin: !P1.16
microsteps: 32
#position_max: 190
#position_min: -6.0
#Sherpa_mini
step_pin: P2.13
dir_pin: !P0.11
enable_pin: !P2.12
microsteps: 32
rotation_distance: 22.067
gear_ratio: 50:10
max_extrude_only_distance: 175
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: P2.7
sensor_type: ATC Semitec 104NT-4-R025H42G
sensor_pin: P0.24
#control = pid
#pid_Kp=34.888
#pid_Ki=5.056
#pid_Kd=60.181
min_temp: 0
max_temp: 280
pressure_advance: 0
[heater_bed]
heater_pin: P2.5
sensor_pin: P0.25
#control = pid
#pid_kp = 71.224
#pid_ki = 1.840
#pid_kd = 689.096
min_temp: 0
max_temp: 130
[fan]
pin: P2.3
serial: /dev/serial/by-id/usb-Klipper_lpc1769_1B300011A99869AF9C2F425EC62000F5-if00
[printer]
kinematics: cartesian
max_velocity: 250
max_accel: 3500
minimum_cruise_ratio: 0.5
#max_accel_to_decel: 2250
max_z_velocity: 2
max_z_accel: 100
#[printer]
#kinematics: limited_cartesian
#max_velocity: 565.685
#max_x_velocity: 400
#max_y_velocity: 400
#max_z_velocity: 2
#max_accel: 5830 # Default acceleration of your choice
#max_accel_to_decel: 5830
#max_x_accel: 5000
#max_y_accel: 3000
#max_z_accel: 50
#scale_xy_accel: True #can be true or false
[temperature_sensor raspberry_pi]
sensor_type: temperature_host
min_temp: 0
max_temp: 100
# TMC2209 configuration
[tmc2209 stepper_x]
uart_pin: P1.10
run_current: 0.600
#sense_resistor: 0.110
#hold_current: 0.600
#stealthchop_threshold: 999
[tmc2209 stepper_y]
uart_pin: P1.9
run_current: 0.600
[tmc2209 stepper_z]
uart_pin: P1.8
run_current: 0.600
#hold_current: 0.450
stealthchop_threshold: 30
[tmc2209 stepper_z1]
uart_pin: P1.1
run_current: 0.600
[tmc2209 extruder]
uart_pin: P1.4
run_current: 0.600
#stealthchop_threshold: 0
#PROBE SECTION#
[bltouch]
sensor_pin: ^P0.10
control_pin: P2.0
x_offset: 32.10
y_offset: -15.20
#z_offset: 0
pin_move_time: 0.680
speed: 3
lift_speed: 20
samples: 2
samples_result: median
sample_retract_dist: 5.0
samples_tolerance: 0.01
samples_tolerance_retries: 3
[safe_z_home]
home_xy_position: 102, 102 # Cambiare le coordinate per il centro del tuo piatto
speed: 100
z_hop: 10 # Move up 10mm
z_hop_speed: 10
[bed_mesh]
speed: 100
horizontal_move_z: 5
mesh_min: 19.60, 1.8
mesh_max:199.1, 190.8
probe_count: 10, 10
adaptive_margin: 2
mesh_pps: 5,5
fade_start: 0.1
fade_end: 10
#fade_target: 0
algorithm: bicubic
bicubic_tension: 0.2
[screws_tilt_adjust]
screw1: -12, 12 #screw coordinates need to be measure for YOUR specific printer
screw1_name: front left screw
screw2: 173, 12
screw2_name: front right screw
screw3: 173, 210
screw3_name: rear right screw
screw4: -12, 210
screw4_name: rear left screw
horizontal_move_z: 10
speed: 50 #speed of travel moves between screws
screw_thread: CW-M3 #measure your bed screw m3=3mm / m4=4mm / m5=5mm
[z_tilt]
z_positions: 0, 102
171.90, 102
171.90, 102
speed: 100
retries: 20
retry_tolerance: 0.001
# EXP1 / EXP2 (display) pins
[board_pins]
aliases:
# EXP1 header
EXP1_1=P1.30, EXP1_3=P1.18, EXP1_5=P1.20, EXP1_7=P1.22, EXP1_9=<GND>,
EXP1_2=P0.28, EXP1_4=P1.19, EXP1_6=P1.21, EXP1_8=P1.23, EXP1_10=<5V>,
# EXP2 header
EXP2_1=P0.17, EXP2_3=P3.26, EXP2_5=P3.25, EXP2_7=P1.31, EXP2_9=<GND>,
EXP2_2=P0.15, EXP2_4=P0.16, EXP2_6=P0.18, EXP2_8=<RST>, EXP2_10=<NC>
# Pins EXP2_1, EXP2_6, EXP2_2 are also MISO, MOSI, SCK of bus "ssp0"
# See the sample-lcd.cfg file for definitions of common LCD displays.
[virtual_sdcard]
path: /home/Restintrip/printer_data/gcodes
[display_status]
[pause_resume]
[idle_timeout]
gcode:M84
timeout: 21600
[force_move]
enable_force_move: True
[input_shaper]
shaper_freq_x: 68.4
shaper_type_x: mzv
shaper_freq_y: 34.4
shaper_type_y: zv
#*# [extruder]
#*# control = pid
#*# pid_kp = 38.731
#*# pid_ki = 4.965
#*# pid_kd = 75.525
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 67.692
#*# pid_ki = 1.489
#*# pid_kd = 769.148
#*# [bltouch]
#*# z_offset = 2.683
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.103750, -0.125625, -0.134375, -0.147500, -0.160625, -0.166875, -0.158125, -0.130625, -0.121250, -0.095625
#*# -0.051250, -0.066875, -0.072500, -0.100000, -0.111250, -0.111250, -0.103125, -0.085000, -0.061250, -0.050625
#*# 0.008125, -0.015000, -0.017500, -0.043125, -0.051875, -0.053125, -0.047500, -0.041875, -0.011875, 0.014375
#*# 0.023125, 0.011875, -0.003125, -0.021250, -0.026875, -0.027500, -0.025625, -0.010625, 0.011250, 0.026875
#*# 0.020625, 0.014375, 0.001875, -0.014375, -0.027500, -0.033750, -0.027500, -0.013750, 0.000000, 0.016250
#*# 0.025625, 0.015000, -0.005625, -0.021875, -0.031250, -0.036875, -0.020000, -0.008750, 0.008125, 0.024375
#*# 0.020000, 0.013125, 0.008125, -0.020625, -0.018750, -0.023125, -0.013750, 0.005625, 0.014375, 0.031875
#*# 0.001250, -0.006250, -0.011250, -0.029375, -0.036250, -0.028750, -0.022500, -0.005625, 0.016875, 0.026250
#*# -0.045625, -0.045000, -0.048125, -0.061250, -0.070000, -0.076875, -0.065000, -0.061250, -0.031250, -0.012500
#*# -0.069375, -0.103125, -0.108125, -0.128125, -0.137500, -0.135625, -0.127500, -0.115625, -0.093750, -0.073125
#*# x_count = 10
#*# y_count = 10
#*# mesh_x_pps = 5
#*# mesh_y_pps = 5
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 19.599999999999994
#*# max_x = 199.06
#*# min_y = 1.8
#*# max_y = 190.8
Firstly, please follow the template when opening such a request. It is there for a reason.
Regarding your issue, your START_PRINT_ADAPTIVE seems incomplete. There is no code that would accept and parse the temperature as handed over by the slicer.
Refer to Using START_PRINT and END_PRINT Macros for an example how it should look like.
Thanks in advice, i fixed and updated the gcode and the section in SuperSlicer and now works like a charm.
this is the gcode updated
	G21; Set all in mm
	G28 ;Home
  M140 S{params.BED_TEMP}; #set bed temperature
	M190 S{params.BED_TEMP}; #wait bed temperature
	M104 S{params.EXTRUDER_TEMP}; #set extruder temperature
  G1 X0 Y0 F3000
	M109 S{params.EXTRUDER_TEMP}; #wait extruder temperature
	G92 E0;
And this is the start Gcode section in SuperSlicer
START_PRINT_ADAPTIVE EXTRUDER_TEMP=[first_layer_temperature] BED_TEMP=[first_layer_bed_temperature]
without the params option klipper wont take variables, i didnt find anything about that, only some old reddit.
Thanks anyway for the support
