What WiFi Extender works best with Klipper
Hi @navyveteran ,
WiFi connection errors are unrelated to Klipper. Also, the Neptune 4 series uses a modified Klipper and Linux system.
3D Printers with Preinstalled and Modified Klipper Versions
With that said, I would first isolate the issue. Can another device connect to the extender? If so, it’s likely a problem with the printer and you should reach out to Elegoo support. If not, reach out to Vonets.
Can you connect the printer to other networks? If so, you can reach out to Vonets support. If not, reach out to Elegoo.
