Hey,
iam currently working on a Klipper moldule and i need to send a gcode command directly to klipper from my module.
I was looking in the firmware_retraction.py and there the “run_script_from_command” method is in use.
And i was already able to set the temperature with this method.
self.gcode.run_script_from_command("SET_HEATER_TEMPERATURE HEATER=extruder TARGET=200\n")
But i am not able to send a G1 command like this.
self.gcode.run_script_from_command("G1 E20 F900\n")
I always get a internal error with G1 command.
I would appreciate some help.
Best regards!
