Wrong direction while homing
Printer Model: Custom CoreXY
MCU / Printerboard: SKR Mini V3
Host / SBC Raspberri Pi 4
Hello Folks! I’m having an issue with homing on my printer.
The homing sequence does not work correctly. When I start homing, the printer first moves Z down by 5 mm. X then homes normally and in the correct direction. However, when it starts homing Y, the gantry moves in the wrong direction.
Instead of moving towards +Y, it moves towards -Y. The Y endstop is located at the back of the printer at Y+220, but during homing Y always travels in the negative direction, away from the endstop.
The CoreXY kinematics seem to be correct, because X moves straight and homes correctly. If the kinematics were wrong, X movement would not be linear.
I tried inverting the Y stepper direction pin, but that causes another problem: after inverting the Y direction, the X endstop no longer triggers correctly. The endstops themselves work properly, as I have testet.
At this point I’m not sure whether this is a configuration issue related to stepper directions, endstop assignments, or CoreXY motor mapping.
Any help or pointers would be greatly appreciated.
[include mainsail.cfg].txt (1.4 KB)
klippy.log (7.0 MB)
Hello @holginator !
Have you tried to set the #homing_positive_dir: flag?
[stepper]¶
Stepper motor definitions. Different printer types (as specified by the "kinematics" option in the [printer] config section) require different names for the stepper (eg, stepper_x vs stepper_a). Below are common stepper definitions.
#   If true, homing will cause the stepper to move in a positive
#   direction (away from zero); if false, home towards zero. It is
#   better to use the default than to specify this parameter. The
#   default is true if position_endstop is near position_max and false
#   if near position_min.
Hi @holginator ,
Your X can be moving in the correct direction (+ to the right), but your Y can be reversed if your A/B steppers are swapped (see the lower left axis diagram).
Setting up CoreXY printers can confusing with X/Y Axis movement.
That’s why I suggest getting a piece of paper and trying to invert the DIR pins as laid out in this post:
